Minimum Packet Size
sivam siva
Level 3
Level 3
Have a basic Doubt
what is the minimum packet size to transmit ?
I have studied that its 64 bytes ,
but some websites says 68 , is it true ?
also i found the packet size below that value , which is  44 bytes for the EIGRP packet (I did this test in serial interface) , is there any exception for control traffic ?
please Find the attached photo which shows packet with 44 bytes
Thanks in advance.
6 Replies 6
balaji.bandi
i would suggest have look,there was  already have massive dicussion here to understand :
https://community.cisco.com/t5/switching/slot-time-and-minimum-ethenet-fame-size/td-p/2797341
still have any more questions, please ask.
BB
Joseph W. Doherty
"also i found the packet size below that value , which is 44 bytes for the EIGRP packet (I did this test in serial interface) , is there any exception for control traffic ? "
Different media have different minimums. I.e. your serial medium likely supports a smaller packet size.
BTW, hope it's clear in the reference that Balaji provided, but much of Ethernet's minimum packet size requirement is due to half duplex media requirements - an example of a common issue where newer technology is often limited by keeping compatibility with earlier standards.
sivam siva
Level 3
Level 3
@Joseph W. Doherty  @balaji.bandi
As peter told frame size must be at least 64 bytes ( which is slot-time of Ethernet to detect the collision ),
so even if the data is not sufficient, device must pad 0s to come up with 64 byte frame. this i could understand.
But if you see my below output Ethernet interface transmits EIGRP packet with 60 bytes , how its possible ?
It might not be counting the FCS (4 bytes).
@Joseph W. Doherty
I think you are right, could you tell me is there any way to confirm it ?
so that I can conclude.
Expand the frame and see if FCS is shown.
