OSPF metric type 1 not incrementing OSPF costs
jeff robins
I am advertising a default route into my OSPF database with the "default-information originate metric-type 1" command. I noticed none of my interface costs are incrementing. Basically not matter what cost I assign an interface, the metric never changes from 1.
I thought type 1 routes will always add the interface costs as it gets propogated.
luis_cordova
Hi @jeff robins ,
To review details about the default-information originate metric-type 1 command, review this discussion:
https://community.cisco.com/t5/routing/ospf-default-info-originate-metric-type-1-vs-always/td-p/1389625
Deepak Kumar
It must be changed. But
There is confusion statement in the OSPF if you are not looking router configuration carefully.  I remember a day when I was stuck on the same and after spending a few hrs I figure out that it was my mistake:
Hope, Your current configuration looking as:
Router ospf 1
default-information originate metric 1
But actually you are not changing your Metric type but you set your E2 route metric.
Let's change OSPF configuration as below:
router ospf 1
 And now you will get success. This is my opinion where we can make a mistake during the configuration.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
