mixing port and vlan based EoMPLS VPN
kjbarrass
Does anyone know if you can have a EoMPLS VPN where one end is terminated to a dot1q subinterface and the other end is port based such as below.
Router1
int fa0/0.1
enc dot1q 1 native
int fa0/0.2
enc dot1q 2
xconnect 10.10.10.102 2 enc mpls
Router2
int fa0/0
xconnect 10.10.10.101 2 enc mpls
When I try to do this in a lab the status of the circuit shows as down and doesnt work but works as soon as I change Router2's end to a subinterface with dor1q vlan of 2.
Does anyone know if the above is possible,
Kind Regards
Kev
adamclarkuk_2
Level 4
Level 4
The only I can see this working is if you make VLAN 2 native on Router 1 instead of VLAN 1. Router 2 will receive the TAG'd frame and bin it. By making VLAN 2 native, no encapsulation will be used so there will be no issue.
Harold Ritter
Kevin,
This can be done using L2VPN Interworking. Please refer to the following link for more information about this feature.
http://www.cisco.com/en/US/docs/ios/12_0s/feature/guide/fsinterw.html#wp1054945
Thanks for the replies, it looks as though on the above link that the "Ethernet to VLAN over AToM (Bridged): Example " example will do just what I need so will test this one out. Do you know what the "interworking ethernet" does under the pseudowire-class statment, does this remove the dot1q tag before passing it down the pseudowire to the peer router.
Kev
