MLS QoS map command missing on 2801
jeff_turl
I am trying to run the following commands on a 2801 router, but the commands are missing:
mls qos
mls qos map cos-dscp 0 8 16 40 32 46 48 56
The only QoS command i have in global config is (no MLS qos) :
REMOTE-ROUTER1(config)#qos ?
  restore-show-output  Restore old show output
  shape-timer          Set the HQF shape timer interval
The router is running IOS:
System image file is "flash:c2801-ipbasek9-mz.151-4.M5.bin"
can someone advise am i just running the incorrect IOS or am i missing somehting, i need to change the QoS Map for my Nortel VoIP.  The VoIP phones connect to a 3750 PoE which used to conenct to a 2651XM to route VoIP and data traffic over the same copper pairs (WAN link to hub site) hence the need for a Service policy but being Nortel phones, require changing the cos-dscp map.  the 2801 is going to replace the 2651XM using a new HWIC.
Jeff
Ryan Newell
Hello Jeff,
MLS QoS stands for multilayer swicthing QoS. 2801 is strictly MQC. Nortel phones connect to 3750 right? Why not configure this on the 3750?
Ryan
It is set on the 3750, i was under the impression i had to also set it on the router as well?
If the goal is to mark cos 5 to dscp 46 and you have configured mls qos trust cos on the Nortel phone ports then the 2801 will not change the marking unless configured to do so. Is there anything else you are trying to do besides marking cos 5 to dscp 46?
Ryan, what i am (maybe mistakenly) trying to do is copy the same config off the current router on to the new router.
all clients connect a 3750, which mas the cos-dscp map, which in turn is trunked to the router:
3750
mls qos
interface range fa 1/0/1 - 48
switchport access vlan 100
switchport voice vlan 200
priority-queue out
mls qos trust dscp
spanning-tree portfast
The current config on the 2651XM is as follows:
controller DSL 0/3/0
mode atm
line-term co
line-mode 2-wire line-zero
dsl-mode shdsl symmetric annex B
line-rate auto
class-map match-any Voice-Media
match ip dscp ef
class-map match-any Voice-Signalling
match ip dscp cs5
policy-map Torbay_VOIP
class Voice-Media
  priority percent 20
class Voice-Signalling
  bandwidth percent 5
class class-default
  fair-queue
  random-detect
interface ATM0/3/0
bandwidth 2312
no ip address
atm restart timer 300
no atm ilmi-keepalive
interface ATM0/3/0.1 point-to-point
bandwidth 2312
ip address 172.25.200.241 255.255.255.252
cdp enable
pvc 0/32
  vbr-nrt 2188 2188 1
  no broadcast
  encapsulation aal5snap
  service-policy output Torbay_VOIP
Hence, i was trying to put the mls qos command onto the 2801 the same as the 2651XM.
jeff
