Modem Question
Kuldeep singh
What is the term for two modems establishing communications with each other ?
(1) Handshaking
(2) Syncing
(3) Pinging
(4) Linking
Please solve my question, actually i am confused with option (1) and (2) .
Generally we use "syncing" word in networking world. But answer is option (1). Why ?
May be answer is wrong in Book. Plz Help
Sandeep Choudhary
Hi Kuldeep,
A handshake is the process by which two devices, such as modems, initiate communication with each other in order to establish a session, in which the devices can exchange any desired information.
This initial communication is necessary because the modems at each end of the line may have different capabilities (such as maximum data transfer speeds), and thus they need to inform each other of their respective capabilities (and settle on the highest transmission speed that both can use). Also, in the case of higher speeds, the modems have to determine the length of line delays so that their echo cancelers can be used properly.
Handshaking begins when one device sends a message to another device indicating that it wants to establish a communications channel. The two devices then send several messages back and forth that enable them to agree on a communications protocol.
Reagrds
Kuldeep,
Handshaking is like 'hello' messages before connecting. The two modems can't be in 'sync' state before Hanshaking.
Sandeep, has given a full answer (Y)
