07-17-2008 04:10 AM - edited 03-03-2019 10:46 PM
Can any body suggest me the command , if I want to modify Auto-Reference path cost in OSPF. My requirement is as-----
10,000(Bandwidth in Mbps)-> 2(Cost)
10(B)-> 2000(C)
1.544(B)-> 12953(C)
0.768(B)-> 26041(C)
07-17-2008 04:43 AM
router ospf n
auto-cost reference-bandwidth 20000
Kevin Dorrell
Luxembourg
07-17-2008 05:07 AM
How you calculated 20000 ( reference Bandw/interface bandw). I want to know what is the base for selecting 20000. Please help
07-17-2008 05:14 AM
It is n, where the cost = n / bandwidth.
=> n = cost * bandwidth
07-17-2008 04:43 AM
Not sure the question.
You do not know the command
or is there another question?
07-17-2008 05:08 AM
How 2000 is selected ? This is the only confustion..
07-17-2008 05:17 AM
The reference bandwidth is in meg
So to get the cost you just divide this number by the bandwidth. Or in your case I just multiplied the cost by the bandwidth.
You had all the calculations correct so figured you knew the 20000 number and had used it for your table.
Edit.... kevin and me agree I guess we jsut post at the same time...
07-17-2008 05:40 AM
I have only one question, how you have calculated 20000 from my requirement. Please help.
07-17-2008 05:45 AM
You said 10000m would be a cost of 2
So cost = reference bandwidth / interface bandwidth
give 2 = reference bandwidth / 10000
you get reference bandwidth = 2*10000 = 20000
07-17-2008 07:24 AM
Got it. Super Help Man. Thanks a lot
