RIP Wont send updates, timer stuck on 0
bill.morton
Trying to setup Rip on a 2811 so that I can route redistribute with a HP switch; problem is that the HP and the Cisco will not form a peer relationship. (EIGRP works fine)
When I debug ip rip, there are no events, packets, updates nothing, so I believe the problem is the cisco router. When I run a 'sh ip prot' the rip shows up, but the send next update timer always stays on 0, so it is never sending updates.
2811-2#sh clock
09:59:47.305 CDT Thu Jul 17 2008
#sh ip prot
Routing Protocol is "rip"
Outgoing update filter list for all interfaces is not set
Incoming update filter list for all interfaces is not set
Sending updates every 30 seconds, next due in 0 seconds
Invalid after 180 seconds, hold down 180, flushed after 240
Redistributing: eigrp 10, rip
Default version control: send version 2, receive version 2
Automatic network summarization is not in effect
Maximum path: 4
Routing for Networks:
192.186.1.0
Routing Information Sources:
Gateway Distance Last Update
Distance: (default is 120)
2811-2#sh clock
10:00:00.385 CDT Thu Jul 17 2008
#sh ip prot
Maximum path: 4
192.186.1.0
2811-2#sh ip int brief
FastEthernet0/0 192.168.1.1 YES NVRAM up up
2811-2#sh run int fa0/0
Building configuration...
Current configuration : 496 bytes
interface FastEthernet0/0
description Link to the LAN 192.168.1.0/24
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
no ip mroute-cache
duplex auto
speed auto
no mop enabled
glbp 50 ip 192.168.1.3
glbp 50 timers 5 18
glbp 50 priority 10
glbp 50 preempt delay minimum 30
glbp 50 load-balancing host-dependent
glbp 50 authentication md5 key-string 7 xxxxxxxx
end
2811-2#term mon
2811-2#debug ip rip
RIP protocol debugging is on
2811-2#sh clock
10:03:18.571 CDT Thu Jul 17 2008
2811-2#
001134: Jul 17 10:03:40.039 CDT: %SEC-6-IPACCESSLOGP: list OutsideACL denied tcp
2811-2#sh clock
10:03:59.811 CDT Thu Jul 17 2008
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(9)T7, RELEASE SOFTWARE (fc3)
lee.reade
Level 4
Level 4
192.186.1.0
ooops...
LR
lee.reade
Level 4
Level 4
192.186.1.0
ooops...
LR
awwww .... fat-fingered it.
Thanks for finding my lex-dysia
