Module support - Cisco C1100TG-1N32A
jvoorend
Information sought.
Does the Cisco C1100TG-1N32A (Terminal Gateway Router) support the C-NIM-2T (Cisco 2-port 100-Mbps/1-Gbps dual-mode GE/SFP, Network Interface Module) module ?
Kind Regards
2 Accepted Solutions
Azizi123
No, the Cisco C1100TG-1N32A (Terminal Gateway Router) does not support the C-NIM-2T (Cisco 2-port 100-Mbps/1-Gbps dual-mode GE/SFP, Network Interface Module).
The C-NIM-2T module is designed for use in specific Cisco platforms such as the Cisco 1100 Series Integrated Services Routers (ISR), which includes models like the ISR 1100 series. The C1100TG-1N32A is part of the Cisco 1000 Series gateway routers, and its supported modules may differ from those supported by the ISR 1100 series.
Azizi123
M02@rt37
Hello @jvoorend
Yes, it is supported:
source: https://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/terminal-services-gateways/nb-06-1100-term-ser-gateway-ds-cte-en.html
Best regards
jvoorend
Many thanks for the above feedback.
That clarifies the details nicely.
Kind Regards
