monitor bandwidth utilization on mlppp link
ciscotac1
hi, what command can i use to check on the bandwidth utilization of a MLPPP link on a Cisco 3825 router.
thanks.
satish_zanjurne
Level 4
Level 4
Below commands would be useful..
"show interface "
"show ppp multilink "
HTH...rate if helpful..
I'm looking for something similar to showing the bits or bytes per second rate used by the whole mlppp link. Will the two commands give me that information? :)
Defintely. You will be able to see the last 5 minutes of usage in the router.
Beyond that, I recommend an analayzing tool that will correlate this data into a database and allow yo uto use it for historical reporting.
I've used various tools to do this - check out MRTG.
Cheers
Scott
