11-11-2010 12:21 PM - edited 03-04-2019 10:26 AM
How to monitor DoS attack on the router? My router is getting aggressive and cutting down the session.
Thanks.
11-19-2010 03:47 PM
One way to find out the traffic coming into or going out of the interface is to enable "ip route-cache flow" under the interface
show ip cache flow command will show you the source and destination interface info to help you track down a specific host that could be causing the issue.
it can be chatty if your cpu is very high i would not recommend.
hope this helps
Raymond
11-20-2010 02:34 AM
I agree with Raymond ,show ip cache flow command will show you the source and destination interface info to help you track down a specific host that could be causing the issue.
Then you can configure Control plane policy to limit the traffic to cpu.
syed.
