Monitor total throughout - ISR4K
Not applicable
Hi, is there a way to monitor the actual platform hardware throughput level on an ISR4K?
Cheers,
Jp
5 Replies 5
show platform hardware throughput level
Hi Hector, that just shows the total that can be used. Not the actual amount being used.
The command that is closest to real time throughput utilization for the ISR 4400 family is:
show platform hardware qfp active datapath utilization
Thanks, is there an OID for this so I can graph it over time?
When comparing with the throughput license, do you only count either input or output?  I imagine 100Mbps through the qfp is what is licensed.  Thanks
And yes, an OID would be nice.
