Nexus Sup1 upgrade from 6.2.8 to 6.2.16
wanwa01
Hi guys
the plan is to upgrade nexus sup1 from 6.2.8 to 6.2.16.
i have run the install command as per below and it looks i can do direct upgrade.
The result is good there is no incompatibility issue
Compatibility check is done:
Module  bootable          Impact  Install-type  Reason
     1       yes  non-disruptive       rolling
     2       yes  non-disruptive       rolling
     5       yes  non-disruptive         reset
     6       yes  non-disruptive         reset
     9       yes  non-disruptive       rolling
    10       yes  non-disruptive       rolling
However, when i check the upgrade guide, for direct upgrade to 6.2.16, the minimum version is 6.2.8(a)
Cisco Nexus 7000 Series NX-OS Software Upgrade and Downgrade Guide, Release 6.x - Cisco
Questions:
1. can i perform direct upgrade from 6.2.8 to 6.2.16 using ISSU or i need to upgrade to supported version first ie 6.2.(8a)
2. If i use manual upgrade, can i directly upgrade to 8.2.16 version? normally how long is the down time?
thanks guys.
Reza Sharifi
Yes, you can go directly to 6.2.16
I would plan on upgrading the switch manually. The boot time should not exceed 15 minutes, so you just need a short window.
