Monitoring Object tracking
rgonzalch
I want to track enhanced object tracking status with solarwinds i mean i wanto to know if the track is up or down for monitoring purposes. Anybody knows how can i get this???
Thanks in advance
Fabrizio Pedracini
to my knowledge there is no OID for the object tracking status. There is the CISCO-RTTMON-MIB which includes several OID's for IP SLA monitoring.
If the advanced tracking object is linked to an IP SLA, you can use the                      rttMonLatestRttOperSense OID to get the latest status code of the IP SLA operation.
.1.3.6.1.4.1.9.9.42.1.2.10.1.2.
If you simply have object tracking, I'm afraid there is no OID to check the up/down status.
hope this helps,
Fabrizio
