Monitoring traffic on subinterfaces
willemvwyk
Hello
If I have a sub interface like s0/2.39 how can I monitor/graph the traffic running over this sub interface?
thanks
wvw
mohammedmahmoud
Level 11
Level 11
You can use simple SNMP tools like CyberGauge.
HTH,
Mohammed Mahmoud.
guruprasadr
Level 7
Level 7
You can use MRTG / Cacti to generate the Graphs by Polling the interface using SNMP Traps.
Pls Rate if Helps
Best Regards,
Guru Prasad R
