More than 2 ISP links on cisco router with Folt tolenrance and load Balance
schuetzm
Dear all,
i checked the forum for the notes about connecting two ISP lines to a single router by using "IOS NAT Load-Balancing". Can this feature be used for more than two lines ??
Thanks and kind regards
Matthias
Richard Burts
Matthias
I am not clear exactly which implementation you are looking at. But I am confident that with appropriate modification it could be used for more than 2 lines. If you could provide details of what you are thinking about doing or the links that you found we may be able to give better answers.
Rick
Rick
Rick,
the distance between our customer's site and the providers dslam-box is to big to get a higher bandwidth than 1 mbps. More significant solutions are to expensive.
So we need to find a moderately priced solution. My challenge is to find a solution for bundling 2,3 or 4 dsl-lines (each with 1 mpbs).
Does IOS-NAT-Load-Balancing support more than 2 links ??
Kind regards
Matthias
Yes.
Haris P
Level 4
Level 4
Dear Matthias ,
I gree that we can do load balancing with more than two ISP lines .
Have a look in the following config . and in additional to this you can add NAT commands 2 or more interface in the same way
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a00808d2b72.shtml
Haris
