move the config to the another switch
homer_mgx
Hi all,
Im new here and just starting with learning about cisco switch's.
So now im trying to move the config from an 3750 to 3750 PoE but without using the PoE options.
I have allready download the config with tftp and upload it to the 3750 PoE. Now the new config is stored on the PoE switch but some of the old setting are still there. Not sure why, i think the config only overwrite the settings which are in the conf file and the setting which are not in the conf file but enabled on it will stay on the switch.
After the upload of the config file I deleted all the config I do not need by hand.
They are some settings i can't delete and I don't know why, hope you can help me.
This are the sittings:
1. each fastethernet port has this option: "no cdp enabled" this entry was no availble on the old switch, is the any possiblity to remove this entry?
2. the same for "no mls qos rewrite ip dscp"
3 and for this one "vlan internal allocation policy ascending"
paolo bevilacqua
Different IOS version behave differently for some commands.
You can re-enable CDP if you want, the other two do not make a difference.
