MP-BGP on GNS3
3amona
Hello Everyone,
im practising MP-BGP on GNS3 and i configured everything.
PE1 routing table
sh ip route vrf co1
Routing Table: co1
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
1.0.0.0/32 is subnetted, 1 subnets
C 1.1.1.100 is directly connected, Loopback1
100.0.0.0/32 is subnetted, 1 subnets
S 100.100.1.1 [1/0] via 10.10.1.5
10.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
C 10.10.1.4/30 is directly connected, FastEthernet0/0
B 10.2.1.0/24 [200/0] via 2.2.2.2, 00:53:56
B 10.1.1.0/24 [20/0] via 100.100.1.1, 01:12:13
as you can see network 10.2.1.0 is reachable via 2.2.2.2
2.2.2.2 is the ibgp peer
and here is the PE1 general routing table
sh ip route
Gateway of last resort is 10.10.4.2 to network 0.0.0.0
C 1.1.1.1 is directly connected, Loopback0
10.0.0.0/30 is subnetted, 5 subnets
i L1 10.10.4.4 [115/20] via 10.10.4.2, FastEthernet0/1
C 10.10.4.0 is directly connected, FastEthernet0/1
i L1 10.10.4.12 [115/40] via 10.10.4.2, FastEthernet0/1
i L1 10.10.4.8 [115/30] via 10.10.4.2, FastEthernet0/1
i L1 10.10.4.16 [115/50] via 10.10.4.2, FastEthernet0/1
i*L1 0.0.0.0/0 [115/40] via 10.10.4.2, FastEthernet0/1
im using isis
now 2.2.2.2 is reachable from PE 1
but when i do ping vrf co1 10.2.1.11, which is a pc on the other end its unreachable
although its reachable when i ping it from PE 2
here is the routiing table of PE 2 for vrf co1
sh ip route vrf co1
Routing Table: co1
2.0.0.0/32 is subnetted, 1 subnets
C 2.2.1.200 is directly connected, Loopback1
S 100.100.1.2 [1/0] via 10.10.2.5
C 10.10.2.4/30 is directly connected, FastEthernet0/1
B 10.2.1.0/24 [20/0] via 100.100.1.2, 02:05:22
B 10.1.1.0/24 [200/0] via 1.1.1.1, 01:05:18
and here is the general routing table on PE 2
sh ip route
i L2 1.1.1.1 [115/70] via 10.10.4.21, FastEthernet1/0
C 2.2.2.2 is directly connected, Loopback0
10.0.0.0/30 is subnetted, 7 subnets
i L2 10.10.4.4 [115/50] via 10.10.4.21, FastEthernet1/0
i L2 10.10.4.0 [115/60] via 10.10.4.21, FastEthernet1/0
i L2 10.10.4.12 [115/30] via 10.10.4.21, FastEthernet1/0
i L2 10.10.4.8 [115/40] via 10.10.4.21, FastEthernet1/0
C 10.10.4.20 is directly connected, FastEthernet1/0
i L2 10.10.4.16 [115/20] via 10.10.4.21, FastEthernet1/0
C 10.10.4.24 is directly connected, FastEthernet0/0
can somebody tell me whats wrong with it that i can ping that device 10.2.1.11 from PE 1
Thank you in advance
0 Replies 0
