Nexus 7000 M2 M3 in the same VDC Issue
tyllin
nexus 7000Hi
my customer want to buy M3 module to extend 10G interface, the original Nexus 7000 have m2xl module, when i create new vdc and change moudle-type to m2xl m3, then allocate interface (m2), it show me some error message
switch(config-vdc)# allocate inter e1/1-4
Moving ports will cause all config associated to them in source vdc to be removed. Are you sure you want to move the ports (y/n)? [yes]
ERROR: 1 or more interfaces are from modules incompatible with current vdc,Please run "(no) system interop-mode m2-m3 module <module>" to change m2 module mode
I try to run "system interop-mode m2-m3 module 1" , this command is not exist!!!!
switch(config-vdc)# system interop-mode m2-m3 module 1
% Invalid command at '^' marker.
How to change interop mode for m2 module?
my Nexus NX-OS version is 7.3(4)D1(1)
balaji.bandi
here is the config guide  : you need to be in global VDC to change the resource.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus7000/sw/vdc/config/cisco_nexus7000_vdc_config_guide/managing-vdc.html
BB
I try to global configure mode or admin vdc, It seems these command not exist.
switch(config)# system internal system interop-mode m2-m3 module 1
i can not simulate your issue
as per the message
BB
It still not recognize this command
switch(config-vdc)# no system interop-mode m2-m3 module 1
switch(config-vdc)# exit
switch(config)# system interop-mode m2-m3 module 1
switch(config)# no system interop-mode m2-m3 module 1
Jonson
