05-19-2013 04:28 PM - edited 03-04-2019 07:56 PM
Hi All-
We have a router connected to MPLS and all the
traffic pass thru the MPLS via the BGP routing.
Recently we installed the local internet and conected
to the router.- location 1. We added the default route "ip route 0.0.0.0 0.0.0.0 x.x.x.x"
route to the local internet on the router, It seems some routes were over writen by this default route-that caused some routing issues.
So we decided not to add the default route to the router and configure Policy Based Route to meet the requirement.
Requirement: In the location 1, we installed the local internet and connected to the router 1. We want the
subnet 1-10.10.1.0/24 can access to the subnet 3-10.10.3.0/24 at the datacente, and all the traffic from
subnet 1 will be re-route to the local internet. Subnet 2-10.10.2.0/24 is not allowed to go thru the local
internet, and its traffic is only permitted to MPLS cloud.
Diagram: See below
Plan to do:
Router1#
G0/0 --> Connect to the internet
ip address 10.10.5.1 255.255.255.0
G0/1 ---> Where the subnet1 is coming from
ip address 10.10.2.1 255.255.255.0
ip policy route-map blah
access-list 100 permit ip 10.10.1.0 0.0.0.255 any
route-map blah permit 10
match ip address 100
set ip default next-hop 10.10.5.1
Questions:
1. Can this PBR meet our requirement?
2. Should we use ip default next hop or ip next hop?
Please advise.
Joe
05-19-2013 06:04 PM
Hi Joe,
The issue seems to be that the DC advertises the default route to the remote sites via the MPLS cloud. When you add the static default route in the remote site, all traffic that needs to go the DC is routed to the local Internet connection since the static default route is preferred over the BGP learned default route. To fix the issue, you could simply advertise a more specific route from the DC towards the MPLS cloud.
If you do not want traffic from subnet 2 to use the local Internet connection, you could just apply an ACL on the interface towards the Internet to block this specific source.
05-19-2013 07:15 PM
Hi Harold,
You're correct. We have the default route in the DC. We tried not to addd the ACL's on the interface towords the internet, we may need to allow the subnet2 by pass through this internet because we may need to add the VPN as backup. So besides your recommendation, do you think the PBR is the best practice? if so, is the configur ok to go? Please advise.
Joe
05-19-2013 07:45 PM
Hi Joe,
From my experience, PBR is not a best practice but rather a last resort.
As far as your configuration is concerned, it pushes all traffic from subnet1 towards the Internet connection as you do not have a specific route to the DC. From what you described in your original post, this does not meet the requirements as traffic destined to the DC will be sent towards the Internet rather than over the MPLS cloud.
One more note, "set ip default next-hop 10.10.5.1" uses the local interface address, when it should rather use the next hop ip address.
