MPLS Configuration on Cisco 1841 Router
vinayak
Dear All,
I want some help in configuration.
We are having 2 Branches (1 Head office & 1 is Branch Office). We are having MPLS Connection between 2 Offices. I am having Internet Connection @ my Head office.
I want to connect two offices using MPLS Connection & Want my Brach OFfice LAN users should use Internet connection which is @ my Head office.
How to do this ?
& Also i am having Cisco ASA 5510 @ head office & Want to apply all the Restiction on Branch office LAN Users Also. Means All the Traffice of Head Office & Branch Office Should follow rules in ASA 5510.
How to do this ?
Please help me ....
21 Replies 21
configure GRE tunnel.................
Dear Ranjit,
I dont know how to establish GRE Tunnel..
Can you give me example.
Or Any link to Document ?
Hi Vinay,
The below IP details at your Head and Branch office...
MPLS IP @ Head office : 10.1.22.21 - 10.1.22.22
INTERNET IP @ Head Office : 1.2.2.2 /30
Head office LAN : 192.168.0.0/24
MPLS IP @ Branch Office : 10.1.22.24 - 10.1.22.25
Brach Office LAN : 192.168.1.0 /24
What is the MPLS router IP and the Management Vlan IP at your head office?
I hope you have a default route configured in your MPLS router at head office like below...
0.0.0.0 0.0.0.0 1.2.2.1
I guess your management VLAN IP at your head office is 192.168.0.1, is that right? If YES
Then you can add a default route like below at your branch office MPLS router to go to the internet traffic on to head office internet link....
0.0.0.0 0.0.0.0 192.168.0.1
Naidu.
Dear Naidu,
@ My head office i terminated both (Internet & MPLS ) Links on same router.
head office Mpls Router IP is : 10.1.22.22
Branch Office MPLS Router IP is : 10.1.22.25
ASA (Default Gateway For Head office LAN) : 192.168.0.1
Is this possible that my BRANCH Office LAN Users can use Internet & follow ASA Rules @ my Head Office after this command :
Hi Vinay,
Yes, it should work please check and update...
And make sure the default gateway at head office LAN: 192.168.0.1 is reachinv over MPLS.
Naidu.
Dear Naidu,
Thanks for Help..
I will let you know after this is done..
i just need to put a static route na:
Like :\
@ Head office to reach Brach Office LAN :
ip route 192.168.1.0 255.255.255.0 10.1.89.21
Default Route for internet : 0.0.0.0 0.0.0.0 1.1.1.1
@ Brach Office:
ip route 192.168.0.0 255.255.255.0 10.1.89.24
For Internet Access : 0.0.0.0 0.0.0.0 192.168.0.1
Is this right ?
Hi Vinay,
Yes, that should work out.
I hope you have already the static routes defined at your head office.
And only thing you have to do at branch office.
Is that correct?
Naidu.
