Cisco IPSec LAN-TO-LAN
mediaos718
I have an IPsec LAN-to-LAN tunnel between a Cisco router and a Palo Alto FW. The tunnel remains UP-ACTIVE if there is interesting traffic - The tunnels goes down if there is no interesting traffic. The problem I am having is that I cannot bring the tunnel up from the Cisco side - If I initiate a ping from the Cisco side to go through the VPN, this will not bring the tunnel up. If I initiate the ping from the Palo Alto side then the tunnel comes up.
How do I have to configure the Cisco router to keep the tunnerl UP-ACTIVE at all time?
How can I bring the tunnel up from the Cisco router side?
rypto isakmp policy 10
encr aes 256
authentication pre-share
group 5
lifetime 28400
crypto isakmp key MYVPN! address x.x.x.x
crypto isakmp invalid-spi-recovery
crypto isakmp keepalive 10 periodic
crypto ipsec transform-set MYSET esp-aes 256 esp-sha-hmac
mode transport
crypto map MYMAP 10 ipsec-isakmp
set peer x.x.x.x
set security-association lifetime kilobytes 65000
set transform-set MYSET
match address Dublin_Subnet
ip access-list extended Dublin_Subnet
permit ip host 192.168.100.1 host 10.117.0.160 log
16 Replies 16
a.alekseev
Level 7
Level 7
What is the 192.168.100.1?
This is a loopback on the local router for testing - When the tunnel is up and running I can ping across using the source loopback interface.
Loopback on local router: 192.168.100.1
IP on the remote side: 10.117.0.160
Cactus-01#ping 10.117.0.160 source loopback 0
Sending 5, 100-byte ICMP Echos to 10.117.0.160, timeout is 2 seconds:
Packet sent with a source address of 192.168.100.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 32/39/48 ms
Disconnect the tunnel
And show the problem
Deb crypto isakmp
Deb crypto IPSec
See attached for the log file.
I disconnected the tunnel and it did not connect back:
Cactus-01#sh crypto session
Crypto session current status
Interface: GigabitEthernet0/1
Session status: UP-ACTIVE
Peer: x.x.x.x port 500
  IKEv1 SA: local x.x.x.x/500 remote x.x.x.x/500 Active
  IPSEC FLOW: permit ip host 192.168.100.1 host 10.117.0.160
        Active SAs: 2, origin: crypto map
Cactus-01#clear crypto session
Session status: DOWN-NEGOTIATING
  IKEv1 SA: local x.x.x.x/500 remote x.x.x.x/500 Inactive
        Active SAs: 0, origin: crypto map
I did not see requested debugs
debug crypto isakmp
debug crypto ipsec
conf t
int GigabitEthernet0/1
no crypto-map XXX
crypto-map XXX
end
Can you check with the administrator of the Palo Alto and verify that their configuration does not specify their role is originator?
I agree that seeing debug output from your machine would probably be helpful, especially at this point the debug for ISAKMP.
Rick
Rick
Hello Richard, As per the admin of the Palo - The Palo is not the originator. In addition, the ACL matches on both ends. I attached a new set of log in the previous reply.
The log that you posted has very interesting information in it. Going through the log I see that negotiation for ISAKMP begins, proceeds, and seems to complete the phase 1 negotiation successfully. But then your router receives a message from the Palo Alto that it should terminate the session
Jul 16 19:55:21.263: ISAKMP:(1275):deleting SA reason "Recevied fatal informational"
state (I) QM_IDLE (peer x.x.x.x)
So it looks to me like your side is ok and that something on the Palo Alto is the cause of the issue. Can they run some debugs or other diagnostics and perhaps identify why they are sending the message to terminate the session?
Rick
Rick
See attached for the new log:
Cactus-01#sh debugging
Generic IP:
  ICMP packet debugging is on
TELNET:
  Incoming Telnet debugging is on
Cryptographic Subsystem:
  Crypto ISAKMP debugging is on
  Crypto IPSEC debugging is on
  Crypto IPSEC Error debugging is on
  Crypto IPSEC states debugging is on
  Crypto IPSEC message debugging is on
  Crypto Key Management Interface debugging is on
IKEV2:
  IKEv2 error debugging is on
  IKEv2 default debugging is on
  IKEv2 packet debugging is on
Cactus-01#
Cactus-01#sh run int gig0/1
Building configuration...
Current configuration : 121 bytes
interface GigabitEthernet0/1
ip address x.x.x.x 255.255.255.0
duplex auto
speed auto
crypto map MYMAP
end
Cactus-01#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Cactus-01(config)#int gig0/1
Cactus-01(config-if)#no crypto map MYMAP
Cactus-01(config-if)#crypto map MYMAP
Cactus-01(config-if)#exi
Cactus-01(config)#exi
Success rate is 0 percent (0/5)
Cactus-01#sh cry
Can you even ping without the crypto map ? Post the full config of your router...
ok
Can you now collect
debug crypto isakmp
debug crypto ipsec
Do the same
conf t
no crypto map MY_MAP
crypto map MY_MAP
end
but start ping from other side.
Generic IP:
TELNET:
IKEV2:
Cactus-01#
duplex auto
speed auto
crypto map MYMAP
end
Cactus-01#conf t
Cactus-01#sh cry
on a side note, with Cisco to Cisco site to site VPNs, the access lists specifying the interesting traffic should mirror each other, I am not sure if that is a requirement for Cisco to Palo Alto as well, but you might want to check what is configured on the Palo Alto side...
I just checked a few PA configs, I am not sure if the Palo Altos support periodic keepalives, I think they require a value. So that means you would have to replace 'periodic' with a value (default is 5 I think):
crypto isakmp keepalive 10 5
