MPLS Internet sharing for branch locations
a-whitehurst
Have 4 locations set up with MPLS, using EIGRP for the routing protocol and BGP for the MPLS. However missing one thing, how to have the branch offices send Internet requests across the MPLS. In EIGRP the local networks are advertised but how do I instruct branch office A for Internet traffic route to HQ?
Are you redistributing from bgp into eigrp at the branches? If so put default-information originate into the bgp config at the hq. The purpose of the command is to create a default route for the other locations.
5 Replies 5
Jeff Van Houten
Level 5
Level 5
Does your hq have default-information originate in the bgp routing config?
No, it is a plain Vanilla EIGRP only advertisng 10/8 net redistribute to BGP group #.  BGP then advertises it's local networks and the neighbor AS which is the provider.
I looked up hte command above but confused on its use and how to to provide a default route from the other routers
That did it, thanks
