MPLS LDP-IGP not working
Hello.
I have two LSRs connecting via single link. I want to check LDP-OSPF synchronization. But it doesnt work. My config for side A:
A#sh run | s ospf
router ospf 1
mpls ldp sync
mpls ldp autoconfig area 0
log-adjacency-changes
network 1.1.1.0 0.0.0.255 area 0
network 10.1.1.0 0.0.0.255 area 0
network 192.168.15.0 0.0.0.255 area 0
network 192.168.0.0 0.0.255.255 area 0
Interface
A#sh run int fa2/1
Building configuration...
Current configuration : 120 bytes
interface FastEthernet2/1
ip address 192.168.5.1 255.255.255.0
duplex auto
speed auto
mpls ip
mpls mtu 1504
end
Side B:
router ospf 1
network 3.3.3.0 0.0.0.255 area 0
network 10.1.3.0 0.0.0.255 area 0
Interface:
B#sh run int fa2/1
ip address 192.168.5.2 255.255.255.0
duplex auto
speed auto
mpls ip
mpls mtu 1504
end
And OSPF starts immediatelly(((
*Jul 22 09:04:04.020: %OSPF-5-ADJCHG: Process 1, Nbr 3.3.3.3 on FastEthernet2/1 from LOADING to FULL, Loading Done
A#
*Jul 22 09:04:25.716: %LDP-5-NBRCHG: LDP Neighbor 3.3.3.3:0 (2) is UP
Bedug for synchronization:
*Jul 22 08:56:03.100: LDP-SYNC: Fa2/1, 3.3.3.3: Peer unreachable; set LDP_CTX_HANDLE_ROUTEUP
*Jul 22 08:56:03.104: LDP-SYNC: Fa2/1, OSPF 1: notify status (required, not achieved, no delay, holddown 30000) internal status (not achieved, timer not running)
*Jul 22 08:56:07.992: %OSPF-5-ADJCHG: Process 1, Nbr 3.3.3.3 on FastEthernet2/1 from LOADING to FULL, Loading Done
So as you can see no impact on OSPF process(((
Please help me what can be wrong
I found the reason. Everything works correctly)
Can you provide the logs & debug outputs for working ldp-igp synch? It will help the other guys having doubts regarding  the same and can compare the same.
Regds,
Ankit Gupta
Ankit Gupta Cisco Systems India
You must look for this:
p1#debug mpls ldp igp sync
LDP-IGP Synchronization debugging is on
*Jul 25 05:26:41.737: %OSPF-5-ADJCHG: Process 1, Nbr 9.0.0.1 on Ethernet0/1 from LOADING to FULL, Loading Done
*Jul 25 05:26:46.785: LDP-SYNC: Peer became reachable on Et0/1, peer 9.0.0.1
*Jul 25 05:26:46.785: LDP-SYNC: Et0/1, OSPF 1: notify status (required, not achieved, delay, holddown infinite) internal status (not achieved, timer not running)
*Jul 25 05:26:46.785: ldp: Check routeup needs; clear routeup needs
*Jul 25 05:26:46.841: LDP-SYNC: Et0/1: No session or session has not send initial update, ignore adj joining event.
*Jul 25 05:26:46.841: %LDP-5-NBRCHG: LDP Neighbor 9.0.0.1:0 (1) is UP
*Jul 25 05:26:46.841: LDP-SYNC: Et0/1: session 9.0.0.1:0 came up, sync_achieved up
*Jul 25 05:26:46.841: LDP-SYNC: Et0/1, OSPF 1: notify status (required, achieved, no delay, holddown infinite) internal status (achieved, timer not running)
show mpls ldp igp sync
    Ethernet0/1:
        LDP configured; LDP-IGP Synchronization enabled.
        Sync status: sync achieved; peer reachable.
        Sync delay time: 0 seconds (0 seconds left)
        IGP holddown time: infinite.
        Peer LDP Ident: 9.0.0.1:0
        IGP enabled: OSPF 1
show ip ospf mpls ldp int e0/1
Ethernet0/1
  Process ID 1, Area 1
  LDP is not configured through LDP autoconfig
  LDP-IGP Synchronization : Required
  Holddown timer is not configured
  Interface is up
Please look at my initial question. There you can see my debug.
So, why i couldn't hold on OSPF, because LDP tried to set the session between loopbacks interfaces and those were unreachable since side A had no another way to reach side B. In this case OSPF cames immidiatelly to try to create LDP session. If no LDP sess is created, OSPF maintains. But if transport addresses are changed to direct IP of physical interfaces (so LDP can create session without OSPF but via direct address), OSPF waits for LDP to come up as it should be.
