MPLS neighbor info
eliaspaulos
why I couldn't see my neighbor Host(device) name.on active MPLS connection.
richard.gosling
Can you expand on this MPLS is a big subject
sdoremus33
Level 3
Level 3
Could you explain further the connection between these hosts I assume that CE-PE connection has problem how is the connection established MP-BGP , static?
Can you ping the egress interface of the PE router from Ce router and also ping via the routing instance
Ex
1) Regular ping from CE to Egress PE
ping
[ip]
address
ping ip address vpn instance
Ex :(See Below)
Ping
Ping x.x.x.x routing instance vpn#. HTH
