12-05-2020 02:09 PM
r2#ping vrf BLUE 10.1.10.1 source gi0/1 repeat 3
r2#sl
Log Buffer (8192 bytes):
NHRP: Receive Traffic Indication via Tunnel0 vrf global(0x0), packet size: 84
(F) afn: AF_IP(1), type: IP(800), hop: 255, ver: 1
shtl: 4(NSAP), sstl: 0(NSAP)
pktsz: 84 extoff: 68
(M) traffic code: redirect(0)
src NBMA: 198.51.100.7
src protocol: 10.1.30.0, dst protocol: 10.1.20.1
Contents of nhrp traffic indication packet:
45 00 00 64 00 67 00 00 FE 01 8A 2E 0A 01 14 01
0A 01 0A 01 08 00 64 11 00 19 00
NHRP-DETAIL: netid_in = 1, to_us = 0
NHRP-DETAIL: Multipath IP route lookup for 10.1.20.1 in vrf BLUE(0x1) yielded GigabitEthernet0/1, pfx:10.1.20.0/24 (netid_in:1 if_in:Tunnel0)
NHRP: nhrp_rtlookup yielded GigabitEthernet0/1
NHRP-DETAIL: netid_out 0, netid_in 1
NHRP: Parsing NHRP Traffic Indication
NHRP: Enqueued NHRP Resolution Request for destination: 10.1.10.1
NHRP: Checking for delayed event NULL/10.1.10.1 on list (Tunnel0 vrf: BLUE(0x1))
NHRP: No delayed event node found.NHRP: Receive Resolution Request via Virtual-Access1 vrf global(0x0), packet size: 79
pktsz: 79 extoff: 52
(M) flags: "router auth src-stable nat ", reqid: 20
src NBMA: 198.51.100.3
src protocol: 10.1.30.2, dst protocol: 10.1.10.1
(C-1) code: no error(0)
prefix: 32, mtu: 17874, hd_time: 600
addr_len: 0(NSAP), subaddr_len: 0(NSAP), proto_len: 0, pref: 255
NHRP: Could not find AVL node for vrf:BLUE(0x1)
NHRP-DETAIL: Multipath IP route lookup for 10.1.10.1 in vrf BLUE(0x1) yielded Null0, pfx:10.1.10.0/24 (netid_in:1 if_in:Virtual-Access1)
NHRP: Route lookup for destination 10.1.10.1 in vrf BLUE(0x1) yielded interface Null0, prefixlen 24
r3#sh ip route vrf BLUE | b ^G
Gateway of last resort is not set
10.0.0.0/8 is variably subnetted, 4 subnets, 3 masks
S 10.1.0.0/16 is directly connected, Null0
B 10.1.10.0/24 [200/0] via 10.1.30.1, 00:37:56
B 10.1.20.0/24 [200/0] via 10.1.30.2, 00:37:10
C 10.1.30.30/32 is directly connected, Loopback10
r3#sh ip cef vrf BLUE 10.1.10.1
10.1.10.0/24
nexthop 10.1.30.1 Virtual-Access2 label 16-(local:18)r2#sh ip nhrp 10.1.10.1/32 (BLUE) Tunnel0 created 00:00:04, expire 00:03:00 Type: incomplete, Flags: negative Cache hits: 2 r2#traceroute vrf BLUE 10.1.10.1 source gi0/1 Type escape sequence to abort. Tracing the route to 10.1.10.1 VRF info: (vrf in name/id, vrf out name/id) 1 10.1.30.30 61 msec 57 msec 31 msec 2 10.1.10.1 87 msec 102 msec 124 msec
vrf definition BLUE rd 1:1 ! address-family ipv4 route-target export 1:1 route-target import 1:1 exit-address-family ! vrf definition RED rd 1:2 ! address-family ipv4 route-target export 1:2 route-target import 1:2 exit-address-family ! interface Loopback1 ip address 10.1.30.0 255.255.255.255 ! interface Virtual-Template1 type tunnel ip unnumbered Loopback1 ip nhrp network-id 1 ip nhrp redirect mpls nhrp tunnel source GigabitEthernet0/2 tunnel protection ipsec profile default ! router bgp 1 bgp log-neighbor-changes bgp listen range 10.1.30.0/24 peer-group Flex neighbor Flex peer-group neighbor Flex remote-as 1 neighbor Flex update-source Loopback1 neighbor Flex timers 5 15 ! address-family vpnv4 neighbor Flex activate neighbor Flex send-community extended exit-address-family ! address-family ipv4 vrf BLUE network 10.1.0.0 mask 255.255.0.0 network 10.1.30.30 mask 255.255.255.255 exit-address-family ! address-family ipv4 vrf RED network 10.1.0.0 mask 255.255.0.0 exit-address-family
12-05-2020 11:40 PM
post the full configs of the hub and the two spokes (sh run). IOSv means you are doing this in VIRL or GNS3 ?
12-06-2020 11:31 AM
12-06-2020 12:51 PM
post the configuration of the Internet router as well, so we can lab this.
12-06-2020 01:14 PM
12-07-2020 12:42 AM
on r3, remove the 'tunnel source' from the virtual template:
ip nhrp redirect
mpls nhrp
--> no tunnel source GigabitEthernet0/2
12-07-2020 01:30 AM
I removed the tunnel source on Gi0/2
This did not solve the problem.
Did you manage to get it working on your side?
# Modification on R3 r3(config)#interface Virtual-Template1 type tunnel r3(config-if)#no tunnel source GigabitEthernet0/2 r3(config-if)#end r3#sh run int Virtual-Template1 Building configuration... Current configuration : 164 bytes ! interface Virtual-Template1 type tunnel ip unnumbered Loopback1 ip nhrp network-id 1 ip nhrp redirect mpls nhrp tunnel protection ipsec profile default # Verification r3#clear crypto ikev2 sa r2#traceroute vrf BLUE 10.1.10.1 source gi0/1 numeric Type escape sequence to abort. Tracing the route to 10.1.10.1 VRF info: (vrf in name/id, vrf out name/id) 1 10.1.30.30 90 msec 52 msec 16 msec 2 10.1.10.1 58 msec 65 msec 78 msec r2#traceroute vrf BLUE 10.1.10.1 source gi0/1 numeric Type escape sequence to abort. Tracing the route to 10.1.10.1 VRF info: (vrf in name/id, vrf out name/id) 1 10.1.30.30 27 msec 51 msec 38 msec 2 10.1.10.1 94 msec 124 msec 37 msec r2#sh ip nhrp 10.1.10.1/32 (BLUE) Tunnel0 created 00:00:25, expire 00:02:39 Type: incomplete, Flags: negative Cache hits: 2
Same issue on R3 during redirection
093386: Dec 7 05:28:31.873: NHRP: Receive Resolution Request via Virtual-Access2 vrf global(0x0), packet size: 79 093387: Dec 7 05:28:31.876: (F) afn: AF_IP(1), type: IP(800), hop: 255, ver: 1 093388: Dec 7 05:28:31.876: shtl: 4(NSAP), sstl: 0(NSAP) 093389: Dec 7 05:28:31.877: pktsz: 79 extoff: 52 093390: Dec 7 05:28:31.878: (M) flags: "router auth src-stable nat ", reqid: 22 093391: Dec 7 05:28:31.879: src NBMA: 198.51.100.1 093392: Dec 7 05:28:31.880: src protocol: 10.1.30.1, dst protocol: 10.1.20.1 093393: Dec 7 05:28:31.884: (C-1) code: no error(0) 093394: Dec 7 05:28:31.885: prefix: 32, mtu: 17874, hd_time: 600 093395: Dec 7 05:28:31.886: addr_len: 0(NSAP), subaddr_len: 0(NSAP), proto_len: 0, pref: 255 093396: Dec 7 05:28:31.887: NHRP-DETAIL: netid_in = 1, to_us = 0 093397: Dec 7 05:28:31.888: NHRP: Could not find AVL node for vrf:BLUE(0x1)
12-07-2020 02:09 AM
actually, not really. I copied the exact configs you have, but r3 says that NHRP is not enabled. I get no NHRP debug output at all on r3.
12-07-2020 03:12 AM
What IOS version are you using?
Did you use GNS3 as well?
12-06-2020 06:58 AM - edited 12-06-2020 12:15 PM
12-06-2020 11:42 AM
Hello
Thanks for the configurations but you are using DMVPN.
In my topology I want to use MPLS over FLEX VPN.
12-06-2020 12:11 PM - edited 12-06-2020 12:18 PM
I check config
only hub have virtual interface
spoke must have tunnel interface
and again check tunnel and virtual source must be in global.
12-06-2020 01:00 PM
Flex VPN is the new way of building VPNs. It support all the use cases of other VPN technologies (including DMVPN) and more.
In this scenario I am using MPLS on top of FLEX VPN to build a multi tenant topology.
(Please see my original post for Cisco pdf).
A spoke uses Tunnel 0 to create a secured control plane connection with the hub, then receives routes for various VRFs via MBGP ... (You can have sources in many VRFs, in this case I have physical links in the BLUE and RED VRFs).
Later on in the process (at the data plane) a NHRP redirect is sent by the hub and the spoke creates (using its virtual template) a direct encrypted point-to-point link to the other spoke.
In my lab, the redirect I sent by the hub but the resolution fails ...
12-06-2020 01:13 PM
Post the config of the Internet router as well. I want to lab this up.
12-06-2020 01:16 PM
I have just sent.
Thank you !
