MPLS Pseudowire is down though preferred interface tunnel is up
aljoush12
Hi Experts,
I am troubleshooting why Pseudowire is down though the preferred path is up. I have Pseudowire configured with the preferred path interface 20 disable-fallback. My tunnel 20 with the preferred path is up. When I run "show mpls l2transport vc 27 detail", it says "Preferred path: Tunnel20,  no route".  I don't know what I am missing here. I have pasted the config and the show commands below. I appreciate it if you could help me troubleshoot the issue.
PE1 Configuration and show commands
interface GigabitEthernet3
 no ip address
 negotiation auto
 no mop enabled
 no mop sysid
 service instance 27 ethernet
  encapsulation untagged
  bridge-domain 27
end
pseudowire-class PW-27
 encapsulation mpls
 preferred-path interface Tunnel20 disable-fallback
l2 vfi TEST manual
 vpn id 27
 bridge-domain 27
 neighbor 22.22.22.22 pw-class PW-27
interface Tunnel20
 ip unnumbered Loopback0
 tunnel mode mpls traffic-eng
 tunnel destination 22.22.22.22
 tunnel mpls traffic-eng path-option 1 explicit name PATH1
end
PE1#show ip explicit-paths name PATH1
PATH PATH1 (strict source route, path complete, generation 45)
    1: next-address 3.3.3.3
    2: next-address 4.4.4.4
    3: next-address 22.22.22.22
PE1#
PE1#show ip interface gigabitEthernet 3
GigabitEthernet3 is up, line protocol is up
  Internet protocol processing disabled
PE1#
PE1#show ethernet service instance id 27 interface gigabitEthernet 3
Id    Type    Interface                     State     CE-Vlans
27    Static  GigabitEthernet3              Up
PE1#show vfi name TEST
Legend: RT=Route-target, S=Split-horizon, Y=Yes, N=No
VFI name: TEST, state: up, type: multipoint, signaling: LDP
  VPN ID: 27
  Bridge-Domain 27 attachment circuits:
  Neighbors connected via pseudowires:
  Peer Address     VC ID        S
  22.22.22.22      27           Y
PE1#show mpls traffic-eng tunnels tunnel 20 detail
Name: PE1_t20                             (Tunnel20) Destination: 22.22.22.22
  Status:
    Admin: up         Oper: up     Path: valid       Signalling: connected
    path option 1, type explicit PATH1 (Basis for Setup, path weight 30)
  Config Parameters:
    Bandwidth: 0        kbps (Global)  Priority: 7  7   Affinity: 0x0/0xFFFF
    Metric Type: TE (default)
    Path-selection Tiebreaker:
      Global: not set   Tunnel Specific: not set   Effective: min-fill (default)
    Hop Limit: disabled [ignore: Explicit Path Option with all Strict Hops]
    Cost Limit: disabled
    Path-invalidation timeout: 10000 msec (default), Action: Tear
    AutoRoute: disabled LockDown: disabled Loadshare: 0 [0] bw-based
    auto-bw: disabled
    Fault-OAM: disabled, Wrap-Protection: disabled, Wrap-Capable: No
  Active Path Option Parameters:
    State: explicit path option 1 is active
    BandwidthOverride: disabled  LockDown: disabled  Verbatim: disabled
  Binding SID: 17
  Node Hop Count: 3
  InLabel  :  -
  OutLabel : GigabitEthernet2, 18
  Next Hop : 172.21.23.1
  RSVP Signalling Info:
       Src 11.11.11.11, Dst 22.22.22.22, Tun_Id 20, Tun_Instance 208
    RSVP Path Info:
      My Address: 172.21.23.2
      Explicit Route: 172.21.23.1 172.22.24.1 172.22.25.1 22.22.22.22
      Record   Route:   NONE
      Tspec: ave rate=0 kbits, burst=1000 bytes, peak rate=0 kbits
    RSVP Resv Info:
      Record   Route:   NONE
      Fspec: ave rate=0 kbits, burst=1000 bytes, peak rate=0 kbits
  Shortest Unconstrained Path Info:
    Path Weight: 30 (TE)
    Explicit Route: 172.22.20.2 172.22.21.2 172.22.22.2 22.22.22.22
  History:
    Tunnel:
      Time since created: 3 days, 22 hours, 16 minutes
      Time since path change: 10 minutes, 21 seconds
      Number of LSP IDs (Tun_Instances) used: 208
    Current LSP: [ID: 208]
      Uptime: 10 minutes, 21 seconds
    Prior LSP: [ID: 202]
      ID: path option unknown
      Removal Trigger: all sub-LSPs of the tspsetup are down
PE1#
PE1#
PE1#ping mpls traffic-eng tunnel 20
Sending 5, 72-byte MPLS Echos to Tunnel20 Active LSP,
     timeout is 2 seconds, send interval is 0 msec:
Codes: '!' - success, 'Q' - request not sent, '.' - timeout,
  'L' - labeled output interface, 'B' - unlabeled output interface,
  'D' - DS Map mismatch, 'F' - no FEC mapping, 'f' - FEC mismatch,
  'M' - malformed request, 'm' - unsupported tlvs, 'N' - no label entry,
  'P' - no rx intf label prot, 'p' - premature termination of LSP,
  'R' - transit router, 'I' - unknown upstream index,
  'l' - Label switched with FEC change, 'd' - see DDMAP for return code,
  'X' - unknown return code, 'x' - return code 0
Success rate is 100 percent (5/5), round-trip min/avg/max = 19/28/41 ms
 Total Time Elapsed 157 ms
PE1#
PE1#traceroute mpls traffic-eng tunnel 20
Tracing MPLS TE Label Switched Path on Tunnel20 Active LSP, timeout is 2 seconds
  0 172.21.23.2 MRU 1500 [Labels: 18 Exp: 0]
L 1 172.21.23.1 MRU 1500 [Labels: 29 Exp: 0] 76 ms
L 2 172.22.24.1 MRU 1500 [Labels: implicit-null Exp: 0] 110 ms
! 3 172.22.25.1 31 ms
PE1#
PE1#show mpls l2transport vc 27 detail
Local interface: VFI TEST vfi up
  Interworking type is Ethernet
  Destination address: 22.22.22.22, VC ID: 27, VC status: down
    Last error: Local access circuit is not ready for label advertise
    Output interface: none, imposed label stack {}
    Default path: disabled
    No adjacency
  Create time: 3d21h, last status change time: 3d21h
    Last label FSM state change time: 3d21h
  Signaling protocol: LDP, peer unknown
    Targeted Hello: 11.11.11.11(LDP Id) -> 22.22.22.22, LDP is DOWN, no binding
    Graceful restart: not configured and not enabled
    Non stop routing: not configured and not enabled
    Status TLV support (local/remote)   : enabled/None (no remote binding
      LDP route watch                   : enabled
      Label/status state machine        : local standby, AC-ready, LnuRnd
      Last local dataplane   status rcvd: No fault
      Last BFD dataplane     status rcvd: Not sent
      Last BFD peer monitor  status rcvd: No fault
      Last local AC  circuit status rcvd: No fault
      Last local AC  circuit status sent: DOWN(hard-down)
      Last local PW i/f circ status rcvd: No fault
      Last local LDP TLV     status sent: No fault (withdrawn)
      Last remote LDP TLV    status rcvd: None (no remote binding)
      Last remote LDP ADJ    status rcvd: None (no remote binding)
    MPLS VC labels: local 34, remote unassigned
    Group ID: local n/a, remote unknown
    MTU: local 1500, remote unknown
    Remote interface description:
  Sequencing: receive disabled, send disabled
  Control Word: On (configured: autosense)
  SSO Descriptor: 22.22.22.22/27, local label: 34
  Dataplane:
    SSM segment/switch IDs: 0/4103 (used), PWID: 1
  VC statistics:
    transit packet totals: receive 0, send 0
    transit byte totals:   receive 0, send 0
    transit packet drops:  receive 0, seq error 0, send 0
PE1#
PE2 configuration and show commands
interface GigabitEthernet2
 no ip address
 negotiation auto
 no mop enabled
 no mop sysid
  bridge-domain 27
end
 encapsulation mpls
l2 vfi TEST manual
 vpn id 27
 bridge-domain 27
 neighbor 11.11.11.11 pw-class PW-27
interface Tunnel20
 tunnel destination 11.11.11.11
end
PE2#show ip explicit-paths name PATH1
PATH PATH1 (strict source route, path complete, generation 188)
    1: next-address 4.4.4.4
    2: next-address 3.3.3.3
    3: next-address 11.11.11.11
PE2#
PE2#show ethernet service instance id 27 interface gigabitEthernet 2
27    Static  GigabitEthernet2              Up
PE2#
PE2#show vfi name TEST
  VPN ID: 27
  11.11.11.11      27           Y
PE2#
PE2#show mpls traffic-eng tunnels tunnel 20 detail
Name: PE2_t20                             (Tunnel20) Destination: 11.11.11.11
  Status:
  Config Parameters:
    auto-bw: disabled
  Binding SID: 35
  Node Hop Count: 3
  InLabel  :  -
  OutLabel : GigabitEthernet4, 33
  Next Hop : 172.22.25.2
       Src 22.22.22.22, Dst 11.11.11.11, Tun_Id 20, Tun_Instance 6
    RSVP Path Info:
      My Address: 172.22.25.1
      Explicit Route: 172.22.25.2 172.22.24.2 172.21.23.2 11.11.11.11
      Record   Route:   NONE
    RSVP Resv Info:
      Record   Route:   NONE
  History:
    Tunnel:
      Time since created: 41 minutes, 11 seconds
      Time since path change: 20 minutes, 1 seconds
      Number of LSP IDs (Tun_Instances) used: 6
    Current LSP: [ID: 6]
      Uptime: 20 minutes, 1 seconds
    Prior LSP: [ID: 1]
PE2#
PE2#
PE2#traceroute mpls traffic-eng tunnel 20
  0 172.22.25.1 MRU 1500 [Labels: 33 Exp: 0]
L 1 172.22.25.2 MRU 1500 [Labels: 36 Exp: 0] 29 ms
L 2 172.22.24.2 MRU 1500 [Labels: implicit-null Exp: 0] 16 ms
! 3 172.21.23.2 60 ms
PE2#
PE2#ping mpls traffic-eng tunnel 20
Success rate is 100 percent (5/5), round-trip min/avg/max = 30/31/35 ms
 Total Time Elapsed 170 ms
PE2#
PE2#show mpls l2transport vc 27 detail
  Destination address: 11.11.11.11, VC ID: 27, VC status: down
    No adjacency
  Create time: 00:39:03, last status change time: 00:39:03
    Last label FSM state change time: 00:39:03
    Targeted Hello: 22.22.22.22(LDP Id) -> 11.11.11.11, LDP is DOWN, no binding
      Last local AC  circuit status sent: Not sent
      Last local LDP TLV     status sent: No status
    MPLS VC labels: local 24, remote unassigned
  SSO Descriptor: 11.11.11.11/27, local label: 24
  Dataplane:
    SSM segment/switch IDs: 0/0 (used), PWID: 1
  VC statistics:
PE2#
Thank you
Harold Ritter
Hi @aljoush12 ,
It appears the targeted LDP might not be up for some reason. Can you please provide the output for "show mpls ldp dis" and "show mpls ldp bind" from both PEs?
Harold Ritter
Hi @aljoush12 ,
Hi @Harold Ritter
Thank you so much for your reply and point me out what to look for. There were no ldp bindings. After doing "no mpls ip" then "mpls ip" in the global configuration, I started seeing the ldp bindings.  Looks like mpls ip is enabled globally in IOS-XE by default. Thank you again for your help.
You are very welcome @aljoush12 and thanks for the feedback
