ISP reachability
ankitohc
Hello Experts,
We are having some intermittent issue with internet.
When I did traceroute the ISP IP
I found the below sometime I get RTO on 7 hop. What does it mean? Can anyone please explain?
Hello @ankitohc ,
the traceroute command is one of the tools used in troubleshooting IP connectivity issues in a network. It works by sending ICMP or UDP packets to every host along a route to the destination host you entered in the traceroute command. It starts sending the packets with TTL=1 so the packets don't go beyond the first hop which will send back to the source a TTL Exceeded message.
For each hop, the source send 3 packets and record the round trip time for each of the packets.
If a hop on the route doesn't send a reply back to the source, for example icmp is restricted by an access-list, a * is printed instead of the round trip time.
Hope this helps.
Regards, LG
*** Please Rate All Helpful Responses ***
Thank you for the answer however why it replies sometime and sometime it does not- as you see in the image
It can happen that some of the probes sent will timeout and other ones don't.
Regards, LG
Ruben Cocheno
@ankitohc
You see that behaviour often when devices out there don't allow tracerouteso you do see those * on it
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
