Showing results forĀ
Search instead forĀ
Did you mean:Ā
mpls redundancy over gre tunnel
i have two cisco router model 2921 connected with two circuit  vpn over mpls  with one isp. we need configure gre tunnel for two circuit ,
also how can configure two circuit to operate active - passive . if one of these circuit down all information go through second circuit .
if can configure active - active for two circuits.
please help me urgent
thanks
Robert Taylor
Please be a little more clear about your topology ...
Are you saying that you have 2 separate mpls providers connected to each of the 2900 routers?  And you want to create a gre tunnel that can use either ISP as transport, in an active/backup scenario?
If not, please be more clear on your physical topology and desired means of packet transport.
Rob
Dear Rob ,
Yes I have two separate mpls providers connected to each of 2900 routers.
