MPLS routing question
carl_townshend
Hi all
When I get an MPLS from my provider, If I have site A and site B both with CE routers,  would these 2 routers look like they are directly connected via the providers network?
How is this done?
cheers
Joseph W. Doherty
Disclaimer
The    Author of this posting offers the information contained within this    posting without consideration and with the reader's understanding that    there's no implied or expressed suitability or fitness for any  purpose.   Information provided is for informational purposes only and  should not   be construed as rendering professional advice of any kind.  Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In    no event shall Author be liable for any damages whatsoever  (including,   without limitation, damages for loss of use, data or  profit) arising  out  of the use or inability to use the posting's  information even if  Author  has been advised of the possibility of such  damage.
Posting
Depends on what the MPLS provider can provide and is providing.  You might have what appears to be a direct p2p L2 connection,or eBGP peering to a provider ASN, or native MPLS, or etc.
fb_webuser
Level 6
Level 6
With L2 MPLS circuit the Service Provider can provision L2 circuits over MPLS, but when you are talking about CE-routers, generally speaking your are talking about a L3 MPLS VPN. Your CE-routers will be communicating with the Service Provider's PE routers, hopefully with BGP, but possibly your IGP protocol of choice. If you are running EIGRP or OSPF, normally thing will look like they were pretty much connected within the same local routing domain. I usually recommend BGP for CE-PE routing, but there are of course scenarios that will force you to make decisions to choose other protocols. EIGRP and OSPF will work just fine, if your SP supports it, as long as they are not multi-homed. If they are multi-homed, you have to implement mechanisms or "tags" to tell the PE routers where the traffic is coming from, but I won't go in to them here. Have fun
Atle
Posted by WebUser Atle Ørn Hardarson
jamiegrive
It really depends on the service being offered - MPLS VPN, EoMPLS, VPLS, etc.
