MPLS ROUTING
Dea Friends,
I have two offices ,one is branch office and other is head office.Two MPLS link is connected with each other,One link is always back up when other link is goes down .
In running time only one link is working other  as a standby but i want to use both link as bandwith sharing and link sharing.If any one goes down then other should take all the data load and it should sena a email.
Please any one have configuration.
JohnTylerPearce
Level 7
Level 7
What routing protocol are you using between the sites? I'm assuming you're using a routing protocol to advertise your networks into your VRF. Also, are both links the same speed or different speeds?
