Cisco 3560x series switch
KAMAL MISHRA
           Hi ,
i have cisco 3560x 24 port switch  series switch i have installed C3KX-NM-10G module on same switch
Problem :
when i connect SFP on G1,G3,G4/te2 ports are not active
only G2/te1 is active but when i connect same module and SFP on other Same Model 48 port switch SFP and module are working
my requirement is
one port is connect to 48 port switch for uplink and another is going to LIU
pls guide how to make all ports active on 24 port switch.
beacuse Termination of  LIU and uplink both we reuire on 24 port switch.
when you use the module C3KX-NM-10G on switch 3560x the ports that you can use are a conbination of:
G1,G2,G3,G4 with sfp at 1 G or
G1,G2 with sfp at 1G and Te2 with sfp+ 10G  or
Te1 with sfp+ at 10G and G3,G4 with sfp at 1G or
Te1 with sfp+ 10G and Te2 with sfp+ at 10G
You can choose the conbination above.
You cannot use G1 and Te1 or G3 and Te2 at the same time
Dear
ierluigi Torriani thanks.
i will use these combination.
