MPLS Tags not appearing on one side of new MPLS VPN
gregwoodson
I have an already existing 6509 that is going to provide the entire MPLS routing table via route reflector to a new 6509.  Here are the relevant configs:
EXISTING 6509 (Router A)
interface Loopback0
 ip address 10.255.2.2 255.255.255.255
end
router bgp 23532
 no bgp default ipv4-unicast
 bgp log-neighbor-changes
 neighbor 10.255.2.3 remote-as 23532
 neighbor 10.255.2.3 update-source Loopback0
 address-family ipv4 mdt
  neighbor 10.255.2.3 activate
  neighbor 10.255.2.3 send-community extended
  neighbor 10.255.2.3 route-reflector-client
  neighbor 10.255.2.3 soft-reconfiguration inbound
 exit-address-family
 address-family vpnv4
  neighbor 10.255.2.3 next-hop-self
  bgp redistribute-internal
 exit-address-family
 address-family ipv4 vrf CustomerA
  redistribute connected
  redistribute static
  no synchronization
 exit-address-family
DAL-COLO-6509-1#show mpls ldp neighbor 10.255.2.3
    Peer LDP Ident: 10.255.2.3:0; Local LDP Ident 10.255.2.2:0
        TCP connection: 10.255.2.3.16271 - 10.255.2.2.646
        State: Oper; Msgs sent/rcvd: 647/646; Downstream
        Up time: 06:07:30
        LDP discovery sources:
          Vlan65, Src IP addr: X.X.X.69
        Addresses bound to peer LDP Ident:
          10.255.2.3      X.X.X.69     X.X.X.254    10.10.1.31
DAL-COLO-6509-1#show mpls forwarding-table 10.255.2.3 detail
Local      Outgoing   Prefix           Bytes Label   Outgoing   Next Hop
Label      Label      or Tunnel Id     Switched      interface
257        Pop Label  10.255.2.3/32    22272         Vl65       X.X.X.69
        MAC/Encaps=14/14, MRU=1584, Label Stack{}
        001CB14458000009B6A4B8008847
        No output feature configured
DAL-COLO-6509-1#show mpls ldp bindings 10.255.2.3 32
  lib entry: 10.255.2.3/32, rev 4933
        local binding:  label: 257
        remote binding: lsr: 10.255.2.1:0, label: 131
        remote binding: lsr: 10.255.2.3:0, label: imp-null
DAL-COLO-6509-1#traceroute 10.255.2.3
Tracing the route to 10.255.2.3
  1 69-69.netblk-66-60-69.yada.net (X.X.X.69) 0 msec *  0 msec
DAL-COLO-6509-1#
New 6509 (Router B)
router bgp 23532
 neighbor 10.255.2.2 remote-as 23532
 neighbor 10.255.2.2 update-source Loopback0
  neighbor 10.255.2.2 activate
  neighbor 10.255.2.2 send-community both
  neighbor 10.255.2.2 soft-reconfiguration inbound
 exit-address-family
  neighbor 10.255.2.2 next-hop-self
 exit-address-family
  redistribute static
  no synchronization
 exit-address-family
Br26-COLO-6509-1#show mpls ldp neighbor 10.255.2.2
    Peer LDP Ident: 10.255.2.2:0; Local LDP Ident 10.255.2.3:0
        TCP connection: 10.255.2.2.646 - 10.255.2.3.16271
        State: Oper; Msgs sent/rcvd: 657/657; Downstream
        Up time: 06:16:40
          Vlan65, Src IP addr: X.X.X.70
          10.255.2.2      X.X.X.10     X.X.X.14     X.X.X.5
          66.60.70.18     66.60.75.252    66.60.72.65     66.60.75.81
          10.10.1.40      66.60.70.17     X.X.X.17     66.60.73.161
          X.X.X.70
Br26-COLO-6509-1#show mpls forwarding-table 10.255.2.2 detail
40         Pop Label  10.255.2.2/32    0             Vl65       X.X.X.70
        0009B6A4B800001CB14458008847
Br26-COLO-6509-1#show mpls ldp bindings 10.255.2.2 32
  lib entry: 10.255.2.2/32, rev 40
        local binding:  label: 40
        remote binding: lsr: 10.10.1.30:0, label: 29
        remote binding: lsr: 10.255.2.2:0, label: imp-null
Br26-COLO-6509-1#traceroute 10.255.2.2
Tracing the route to 10.255.2.2
  1 70-69.netblk-66-60-69.yada.net (X.X.X.70) 0 msec *  0 msec
Br26-COLO-6509-1#
Im seeing label switching coming from the old switch (which has several MPLS VPN connections already).  Im not seeing anything from the new switch.  OSPF is the routing protocol between the interfaces, and shows to be working fine.  LDP neighbor relationship seems to be good- just tagging isn’t occurring going back toward the old switch.  Any suggestions?
Greg
11 Replies 11
Giuseppe Larosa
Hello Greg,
because the two devices are directly connected, Penultimate Hop Popping (PHP) applies each device advertise its own loopback in LDP with an implicit null  (should be label 3) and the action is POP label and so the label stack is empty and the packet is sent as a native IP packet as you see also in the traceroute.
What you see is normal behaviour.
You would need three devices connected in a row RA-RB-RC  to see label propagation in action
Hope to help
Giuseppe
I need the MPLS VPN to come up, trade routes, and pass traffic.  No matter what I do- it doesn't seem to fix this.  That's the ultimate issue here.  The new 6509 is acting as a Route Reflector Client getting it's routing table from the old switch.
Greg
Hello Greg,
I see your point.
post from new switch
show ip bgp vpnv4 all summary
only routes matching route targets of locally defined VRFs are actually imported
outside of BGP protocol you need
ip vrf CustomerA
route-distinguisher 1000:1
route-target import 1000:1
route-target export 1000:1
in both routers to build an MPLS VPN
Hope to help
Giuseppe
It's already there:
This is off the new switch:
ip vrf CustomerA
 rd 23532:1
 route-target export 23532:1001
 route-target import 23532:1001
 mdt default 239.232.255.0
Br26-COLO-6509-1#sh ip bgp vpnv4 all summary
BGP router identifier 10.255.2.3, local AS number 23532
BGP table version is 13652, main routing table version 13652
13 network entries using 1781 bytes of memory
13 path entries using 884 bytes of memory
7/4 BGP path/bestpath attribute entries using 1120 bytes of memory
6 BGP rrinfo entries using 144 bytes of memory
3 BGP extended community entries using 72 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
BGP using 4001 total bytes of memory
BGP activity 3997/3970 prefixes, 9542/9515 paths, scan interval 15 secs
Neighbor        V           AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
10.255.2.2      4       23532    7853    3327    13652    0    0 00:02:16       11
Greg
Here is the show ip route statement for the VRF:
Br26-COLO-6509-1#sh ip route vrf CustomerA
Routing Table: CustomerA
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
     10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C       10.105.46.0/24 is directly connected, Vlan217
C       10.253.0.9/32 is directly connected, Loopback2
Hello Greg,
all BGP routes are missing from vrf IP routing table
Can you post a sh version, sh module from new switch?
Only Sup7203B or better supports MPLS services in 6500 platform
Hope to help
Giuseppe
Yes- that is the problem we are trying to fix.
Br26-COLO-6509-1#sh ver
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(33)SXI13, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Tue 11-Mar-14 04:53 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX5, RELEASE SOFTWARE (fc1)
 Br26-COLO-6509-1 uptime is 1 day, 49 minutes
Uptime for this control processor is 1 day, 49 minutes
Time since Br26-COLO-6509-1 switched to active is 1 day, 48 minutes
System returned to ROM by reload at 09:20:45 CDT Wed May 7 2014 (SP by reload)
System restarted at 09:24:29 CDT Wed May 7 2014
System image file is "disk0:s72033-adventerprisek9_wan-mz.122-33.SXI13.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-E (R7000) processor (revision 1.3) with 458720K/65536K bytes of memory.
Processor board ID SMG1125N74N
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
5 Virtual Ethernet interfaces
154 Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Yes- we do have a Sup7303B in this switch.
Can you do this on the switch where the prefixes are not installed:
sh ip bgp vpnv4 vrf CustomerA
To see if you receive these via BGP
Alain
We are not receiving any routes/MPLS tags from the switch.
Br26-COLO-6509-1#sh ip bgp vpnv4 vrf CustomerA
BGP table version is 421, local router ID is 10.255.2.3
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
Route Distinguisher: 23532:1 (default for vrf CustomerA)
*> 10.105.46.0/24   0.0.0.0                  0         32768 ?
*> 10.253.0.9/32    0.0.0.0                  0         32768 ?
check your import/export policy on both routers
Could u disable default PE router behavior by configuring no bgp route target filter command under BGP to see all routes send through BGP vpnv4 table ,then use sh bgp vpn4 un all command to verify BGP routes.
Ashish
gregwoodson
Anyone have any ideas?
