MPLS VPN L3 act as primary connection while IPSec over the internet acts as a 2nd connection
Ibrahim Jamil
Level 6
Level 6
Hello guys
any good config example for MPLS VPN L3 act as primary connection while IPSec over the internet acts as a 2nd connection , routing protocol is OSPF
thanks
6 Replies 6
Deepak Kumar
You can change the OSPF cost and make it primary.
https://supportforums.cisco.com/t5/network-infrastructure-documents/how-to-configure-ospf-cost/ta-p/3133153
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hi Kumar
thanks for ur reply
i m looking for config example   MPLS VPN L3 act as primary connection while IPSec over the internet acts as a 2nd connection
thanks
I give me some time and I will share with you.
Deepak Kumar
Deepak Kumar,
thank you bro kumar , this type of connection seems a trend nowdays
You can configure the route-map and set the next-hop address. I  am sharing the details with you as an example:
IP local LAN subnet:  10.10.10.0/24
My HO site Subnet: 192.168.2.0/24
I have two tunnel interface:
Tunnel 1: 1.1.1.0/24 - MPLS network
Tunnel 2: 2.2.2.0/24 - Internet VPN
The configuration of route-map on remote as below:
ACL configuration for interested traffic:
access-list 100 permit ip any 192.168.2.0 0.0.0.255
Route-map configuration and assign the next hop address:
route-map test permit 10
match ip address 100
 set ip next-hop verify-availability 1.1.1.2 1 track 100
Apply the route-map under the LAN interface:
interface FastEthernet1/1
des Local-LAN
ip address 10.10.10.1 255.255.255.0
ip policy route-map test
speed auto
duplex auto
and add an IPSLA and Track to monitor the next-hop availability.
ip sla 100
icmp-echo 1.1.1.2 1 source-interface Tunnel1
threshold 2
timeout 1000
frequency 3
ip sla schedule 100 life forever start-time now
track 100 ip sla 100 reachability
Deepak Kumar
Deepak Kumar,
thanks kumar
