mpls
mailaglady2
Level 5
Level 5
I have 2 router (7602 VXR) and configured mpls but it cannot see the neighbor,below are my configs. what could be a problem.
R1
ip cef
interface ATM3/0.100 point-to-point
ip address 165.148.120.2 255.255.255.252
no atm enable-ilmi-trap
mpls label protocol ldp
mpls ip
pvc 1/100
encapsulation aal5snap
router ospf 1
log-adjacency-changes
network 165.148.120.0 0.0.0.3 area 0
network 192.5.1.0 0.0.0.255 area 0
R2
ip cef
interface ATM1/0.100 point-to-point
ip address 165.148.120.1 255.255.255.252
mpls ip
pvc 1/100
router ospf 1
network 192.1.1.0 0.0.0.255 area 0
Giuseppe Larosa
Hello Lawrence,
you need
mpls ip
in global config mode
you can use
sh mpls int
sh mpls ldp disc
to troubleshoot LDP
sh mpls forwarding
Hope to help
Giuseppe
12 Replies 12
Giuseppe Larosa
Hello Lawrence,
you need
mpls ip
you can use
sh mpls int
sh mpls ldp disc
to troubleshoot LDP
sh mpls forwarding
Hope to help
Giuseppe
I tried all of above but still no luck, i'm so confused. I started with this problem ever since this morning
If you eliminate mpls, does it work ?
Make sure you include the MPLS RouterID in your IGP (commonly forgotten) and consider using also the command "mpls ldp router-id" to make sure you know what your MPLS RouterID is supposed to be.
Hello Lawrence,
post the output of
sh mpls ldp discovery
on both routers
Hope to help
Giuseppe
Hi everyone
My problem here was i completely forgot to include my loopback on the router protocol advertisements. if you can check I was using OSPF, little thing might cost you an arm and a leg.
Thanks for all the efforts in trying to help and I truly appreciate that.
You might have rated a post with a 1.0 by mistake, but for your reference this is considered an insult in this forum...
Hi Giuseppe Larosa
I wanted to rate you at 3 but I truly don't know what happened. I was only made aware now by maria if you can refer to other posts on these same topic.
No offence or sarcasm intended, I truly apologise and I tried to rectify this but the rating don't go under your name.
If you know me or have seen all my comments you can see that i truly appreciate people that take an effort to try and help others and please keep up the good work. Don't let little things disturb/shift your focus and never stop being good as you are at this stage.
Don't worry. Most people that kept responding here understood this was a mistake. We also keep responding even in situations where the comments are not so good. I told you about this only to inform you to be more careful. I came here to rectify the 1.0 situation with my own vote since Guiseppe definitely does not deserve a 1.0 . I just didn't think of this earlier. I did the math when you said 3 (5+1)/2=3 and we are now all set, although Guiseppe's average will require more votes to be straight back, but I am sure he will rectify this soon on his own 🙂
Also, I came here to comment on your technical issue. OSPF does not require the RouterID to be advertised by OSPF (OSPF internal procedures figure things out), unless you are trying to specifically ping the RID. MPLS on the other hand requires the MPLS RID to be in the IGP (OSPF in your case) or MPLS neighbors will not be formed. The loopback you mentioned is probably the MPLS RID. I am not saying this to emphasize how I detected your issue, but to make you aware of the reasons that caused the issue and why it was resolved. In every case you come across, try to make conclusions about such things.
Hello Lawrence,
no problem at all it was strange to see an answer rated 1 and flagged as solved
You are wellcome
Best Regards
Giuseppe
Thanks, that made me feel better.
Maria thanks to you too.
Guiseppe described very well the reason we understood it was a mistake. He said it was strange, but when I saw just the title of the conversation being resolved with one vote of 1.0, I thought that this case must be funny! 🙂
Also, avoid marking your issue as resolved before it actually is, because it might cause some people to prefer to read something that has not been resolved yet and leave the resolved for later reading.
