MPLS
While setting up a new site (in Hub & spoke topology) into a MPLS cloud, can some one give a general guide line to do the configuration ? Any good documentation over MPLS with work.
Thanks & Regards:
Gary Triv
Network Eng & Data Center Consultant
CCNA, CCDA, CCNP, CCDP, CCIE Written,
MCTS, MCITP, OCA, SAP, BS & MS (I.T)
Laurent Aubert
HI Gary,
You should use two RT: one for the hub and one for the spokes.
PE connected to the spoke import only the RT associated to HUB networks and the PE connected to hub will import the RT associated to spoke subnets.
This way you will not have spoke-2-spoke communication.
Laurent.
