MQC question
Maurice Ball
Level 3
Level 3
Could someone please help me with the following QoS issue? I setup a small QoS lab to get familiar with the MQC setup. The problem I am having is I can't get the packets to go in to the correct queues.The packets are being marked correctly when they enter the router but they are not going in the correct queues when they are being queued to leave the router. It looks like all packets are using the class-map  "class-default".Could someone give me some insight to why this is happening? The configuration is attached and also the output from the show policy-map on both interfaces. Thanks in advance.
Michael Lee
Hi Maurice,
Can you remove the section of configuration below and retest?
policy-map SHADE_2MB
 class All_TRAFFIC
    shape average 2000000
  service-policy PRIORITY
It is calling the same policy-map, and I'm wondering if it's interfering with the results.
Cheers,
Mike
Hi Mike,
I remove the nested policy-map as you suggested but I am still getting the same results. The packets are still not queuing correctly.
LocalRT#show policy-map interface f0
 FastEthernet0
  Service-policy output: PRIORITY
    queue stats for all priority classes:
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 0/0
    Class-map: MATCH_AF11 (match-any)
      0 packets, 0 bytes
      30 second offered rate 0 bps, drop rate 0 bps
      Match:  dscp af11 (10)
        0 packets, 0 bytes
        30 second rate 0 bps
      Queueing
      bandwidth 10% (10000 kbps)
        Exp-weight-constant: 9 (1/512)
        Mean queue depth: 0 packets
        dscp     Transmitted       Random drop      Tail drop          Minimum        Maximum     Mark
                  pkts/bytes     pkts/bytes       pkts/bytes          thresh         thresh     prob
    Class-map: MATCH_AF21 (match-any)
      0 packets, 0 bytes
      Match:  dscp af21 (18)
        0 packets, 0 bytes
      Priority: 50% (50000 kbps), burst bytes 1250000, b/w exceed drops: 0
    Class-map: class-default (match-any)
      76 packets, 8377 bytes
      Match: any
      Queueing
      (queue depth/total drops/no-buffer drops/flowdrops) 0/0/0/0
      (pkts output/bytes output) 91/9610
      Fair-queue: per-flow queue limit 16
