MRTG - Implementation Help Required
guruprasadr
Level 7
Level 7
Hello All,
I need to implement MRTG in our customer premesis with all features.
Pls help me in MRTG implementation & Configuration. If possible can anyone provide me the Complete Configuration file of MRTG(with all features included), so that i can modify the same as per my requirement.
Thanks & Regards,
Guru Prasad R
5 Replies 5
sanuchakkalayil
hai..
Give ur mail id..i ll send the configuration guide..
rgrds
sanal babu
HI Sanal Babu,
Thanks. Please send me the Complete Configuration file to:
itguruprasad@yahoo.com
gurupr@hcl.in
Best Regards,
Guru Prasad R
Amit Singh
A complete "MRTG Implementation Manual" is now available online at:
http://www.enterastream.com/whitepapers/mrtg/mrtg-manual.html
The manual covers all MRTG deployment topics, including the standard MRTG version and also the RRDTOOL/Database integration.
HTH,Please rate if it does.
-amit singh
you can try PRTG from paessler softwares to begin with ... :-) nice n easy to install..
use snmp community and ul be on ur way ..
btw its GUI based.
HI Amit,
Link provided by you is not opening. Pls Help
Best Regards,
Guru Prasad R
