MSDP Query
ryel.dsouza
In MSDP is it required that the peering be done with another RP only ??? or supposing i have R1 in AS 100 (Being the Rp of that AS) has a MBGP peering with R2 in AS 200 (which is not the Rp on the AS). R3 which is behind R2 in AS 200 is the RP.for the AS
Thanks.
Ryel
solved
is this what you were looking for
R5#ping 230.0.0.1 source lo0
Sending 1, 100-byte ICMP Echos to 230.0.0.1, timeout is 2 seconds:
Packet sent with a source address of 55.55.55.55
Reply to request 0 from 31.0.0.1, 328 ms
Reply to request 0 from 16.0.0.2, 536 ms
i did the follwoing changes to ur config
R3:
address-family ipv4 multicast
network 33.33.33.33 mask 255.255.255.255
becuase in R1:
*Dec 20 23:36:07.899: MSDP(0): 31.0.0.2: Peer RPF check failed for 33.33.33.33,
used IBGP route's peer 0.0.0.0
Then
*Dec 20 23:40:35.035: MSDP(0): 31.0.0.2: Peer RPF check passed for 33.33.33.33,
used EMBGP peer
again in R3:
access-list 10 permit 224.0.0.0 7.255.255.255
access-list 10 permit 230.0.0.0 0.255.255.255
ip pim send-rp-discovery Loopback0 scope 255 group-list 10
also i added default route from R# to R5 to make sure the subnet reachable from remote ssites
by the way looks like you configured R1 and R6 with the group 230.0.0.1 becuase the replay above from both of them
good luck
please if helpful Rate
10 Replies 10
Reza Sharifi
Hello Ryel,
RP.for the AS>
Yes, you can connect to R2 in AS 200, but you have to use your local interface as the source.
Example:
ip msdp peer 192.168.1.4 connect-source ethernet 0/0 remote-as 200
Please refer to this command reference guide for more info and example:
http://www.cisco.com/en/US/docs/ios/ipmulti/command/reference/imc_03.html#wp1056138
Reza
Marwan ALshawi
Hi there
see this document i think will be helpful
https://supportforums.cisco.com/docs/DOC-8293
good luck
if helful Rate
My setup is like this R5 & R3 (Rp) in AS100 & R1 & R6(RP) in AS200. R3 & R1 are having a mbgp peering. Problem is multaiacst traffic generated from R5 for 230.0.0.1 is not reaching R6 lo0 in AS 200. Have added the run config kindly have a look and please help.
Ryel
can you put your diagram please
is this lab test ?
yes it is a lab test
Setup Is
R5 s1/1 ---> R3 s1/1 ----> R3 s1/2 -----> R1 s1/2 ----->  R1 s1/3 ------> R6 s1/3
Kindly Help.
Ryel
you are using
ip msdp peer 31.0.0.1 connect-source Serial1/0
where is s1/0 in the diagram you sent me ?
i can see you trying to use another link bewteen R1 and R3 andyou tying to get RPF check thorugh multicast BGP
logicaly this is valid
the question is
can you make sure your MSDP peer is up
show ip msdp peer
and when you do ping do  debug ip msdp peer route and see the if the SA messages are exchanged about the source or not between the two MSDP peers
by the way you d not need MBGP between R1- R6 or R5 R3 as they have only one link between them OSPF enough to get the normal route
and make sure there is unicast routing as well default route will be enoguh between the two ASs
by the way if you using second link between R1 and R3 using MBGP make sure you recieve the route through MBGP
do
show ip bgp ipv4 multicast
good luck
It Seems my MSDP peering are up but some how multicast traffic traffic is not reaching R6 & yes there is a second link connecting from R3 s1/0 to R1 s1/0 for rpf check.
R1 (sh ip msdp sum)
Peer Address     AS    State    Uptime/  Reset     SA    Peer Name
                                Downtime Count              Count
31.0.0.2         100   Up       05:15:52 0                  0     ?
16.0.0.2         200   Up       01:38:30 0                  0     ?
R1(config)#
R3 (sh ip msdp sum)
MSDP Peer Status Summary
31.0.0.1         100   Up       05:17:02 0             0          ?
R6 (sh ip msdp sum)
16.0.0.1         200   Up       01:41:22 0               0     ?
R6#
R6 (sh ip bgp ipv4 multicast)
BGP table version is 4, local router ID is 66.66.66.66
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*>i55.55.55.0/24    16.0.0.1                 0    100      0 100 i                  <------------------------- Advertised in R5 bgp address family
R6#
solved
R3:
becuase in R1:
Then
used EMBGP peer
again in R3:
good luck
how come the rpf was failing at R1 did not even notice it was going on.
i think in your case the router using thier loopbacks as the sroutrce of MSDP (R3)  not sure but i have to see the debug again but this was the issue
and also u need a reachability between the two domains
the best way is to injuct default routes to R5 and R6 thorugh ospf or bgp
try to use the originator-id command and put the required interface ip address and see if the RPF pass or not
good luck with your study and i am glad its working now
