MTU - Interface vs Tunnel Transport vs IP
vv0bbLeS
Level 3
Level 3
Hello all,
Trying to make sure I understand the different MTU settings on a Tunnel interface. Say I have the following output from a
show interface Tunnel1
MTU 17916 bytes
Tunnel transport MTU 1476 bytes
And say I have the following config set in
show run int Tunnel1:
ip mtu 1360
My understanding of these 3 MTU values is:
  • The 17916 bytes is the physical interface's theoretical max MTU size that it *could* send (maybe this refers to the buffer size of the physical interface, or maybe it is calculated in some other way?)
  • The 1476 is the Tunnel Interface's max MTU size that it *could* send (the 1500 - 24 byte GRE header in this case).
  • The 1360 is the *actual* max MTU size that the Tunnel interface will send on the wire.
Is this a correct understanding? And if so, I'm guessing the
ip mtu 1360
command would only work on a routed interface, i.e. it would not work on an interface that supports Layer 2?
0xD2A6762E
Joseph W. Doherty
"The 17916 bytes is the physical interface's theoretical max MTU size that it *could* send (maybe this refers to the buffer size of the physical interface, or maybe it is calculated in some other way?)"
Tunnels aren't physical interfaces.  It's possible that value was chosen as a maximum to support 16 Mbps token ring.
"The 1476 is the Tunnel Interface's max MTU size that it *could* send (the 1500 - 24 byte GRE header in this case)."
Correct.
"The 1360 is the *actual* max MTU size that the Tunnel interface will send on the wire."
Correct, but it's actually a logical L3 cap, where MTU is a physical L2 cap.  That's why it's labeled
IP MTU
and not just "MTU".
"And if so, I'm guessing the
ip mtu 1360
command would only work on a routed interface, i.e. it would not work on an interface that supports Layer 2?"
Believe that's the case.  A L2 interface has a MTU.  Too large frames are just dropped, no fragmentation option, no notification to sender.  (In theory, physical interfaces on a shared medium should all support the same MTU.)
Joseph W. Doherty
Correct.
IP MTU
and not just "MTU".
ip mtu 1360
Joseph,
Excellent, thanks again for the information! And yes I was curious where that 17916 came from - the 16Mbps token ring sounds very reasonable.
0xD2A6762E
