Multi Phase 2 connections with IPSec Site 2 Site
cloudix
ive got a problem i cant seem to figure out. When my Ipsec tunnel is built it makes a new phase 2 connection every 60 seconds.
1.1.1.1 = Cisco Router
2.2.2.2 PfSense Router
----- Connection configuration -----
1.1.1.1 => Internet <= 2.2.2.2
Here is a screenshot on the Pfsense end.
and Here is the config on the Cisco router.
version 15.5
no platform punt-keepalive disable-kernel-core
hostname Router
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
clock timezone CST -6 0
clock summer-time CDT recurring
ip dhcp excluded-address 10.10.20.1 10.10.20.10
ip dhcp excluded-address 10.10.30.1 10.10.30.10
ip dhcp pool default
network 10.10.20.0 255.255.255.0
default-router 10.10.20.1
dns-server 8.8.4.4
lease 0 1
ip dhcp pool Vlan_10
network 10.10.30.0 255.255.255.0
default-router 10.10.30.1
dns-server 8.8.8.8
lease 0 1
subscriber templating
license udi pid ISR4321/K9 sn FLM2429002E
license accept end user agreement
license boot level appxk9
license boot level securityk9
username admin privilege 15 password 0 XXXXX
redundancy
mode none
crypto ikev2 proposal Nash-Ikev2-Proposal
encryption aes-gcm-128
prf sha256
group 2
crypto ikev2 policy Nash-Ikev2-Policy
match address local 1.1.1.1
crypto ikev2 keyring Cross2Nash-keyring
peer my.domain.com
description "Nashville Connection"
address 0.0.0.0 0.0.0.0
identity fqdn my.domain.com
pre-shared-key XXXXXXX
crypto ikev2 profile Nash-Ikev2-Profile
match identity remote fqdn my.domain.com
authentication remote pre-share
authentication local pre-share
keyring local Cross2Nash-keyring
lifetime 28800
dpd 10 5 on-demand
vlan internal allocation policy ascending
crypto ipsec transform-set Nash-TransformSet esp-aes 256 esp-sha256-hmac
mode tunnel
crypto ipsec profile Nash-IPsecProfile
set transform-set Nash-TransformSet
set pfs group14
set ikev2-profile Nash-Ikev2-Profile
interface Tunnel11
ip address 10.10.40.1 255.255.255.255
ip tcp adjust-mss 1350
tunnel source 1.1.1.1
tunnel mode ipsec ipv4
tunnel destination 2.2.2.2
tunnel protection ipsec profile Nash-IPsecProfile
interface GigabitEthernet0/0/0
description Connected to Port 1 on Switch
no ip address
negotiation auto
no mop enabled
spanning-tree portfast trunk
interface GigabitEthernet0/0/0.2
encapsulation dot1Q 2 native
ip address 10.10.20.1 255.255.255.0
ip nat inside
no cdp enable
interface GigabitEthernet0/0/0.10
encapsulation dot1Q 10
ip address 10.10.30.1 255.255.255.0
ip nat inside
no cdp enable
interface GigabitEthernet0/0/1
ip address dhcp
ip nat outside
negotiation auto
vrf forwarding Mgmt-intf
no ip address
negotiation auto
interface Vlan1
no ip address
ip nat inside source list Nat-Service interface GigabitEthernet0/0/1 overload
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 192.168.5.0 255.255.255.0 Tunnel11
ip ssh rsa keypair-name SSH-Key
ip ssh version 2
ip ssh dscp 16
ip access-list extended IpSec_Tunnel
permit ip 10.10.20.0 0.0.0.255 192.168.0.0 0.0.0.255
permit ip 10.10.20.0 0.0.0.255 192.168.5.0 0.0.0.255
permit ip 10.10.20.0 0.0.0.255 192.168.10.0 0.0.0.255
permit ip 10.10.20.0 0.0.0.255 192.168.128.0 0.0.0.255
remark -= End of Vlan 2 =-
permit ip 10.10.30.0 0.0.0.255 192.168.0.0 0.0.0.255
permit ip 10.10.30.0 0.0.0.255 192.168.5.0 0.0.0.255
permit ip 10.10.30.0 0.0.0.255 192.168.10.0 0.0.0.255
permit ip 10.10.30.0 0.0.0.255 192.168.128.0 0.0.0.255
remark -= End of Vlan 10 =-
permit esp host 2.2.2.2 host 1.1.1.1
permit udp host 2.2.2.2 eq isakmp host 1.1.1.1
permit udp host 2.2.2.2 eq non500-isakmp host 1.1.1.1
ip access-list extended Nat-Service
remark "-=[Define NAT Service]=-"
permit ip 10.10.20.0 0.0.0.255 any
permit ip 10.10.30.0 0.0.0.255 any
logging trap warnings
control-plane
end
Any help with this would be awesome.
25 Replies 25
show crypto isakmp sa <<- share this
MHM
Nothing for isakmp, so i also included ipsec
#show crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst src state conn-id status
IPv6 Crypto ISAKMP SA
#sh crypto ipsec sa
interface: Tunnel11
Crypto map tag: Tunnel11-head-0, local addr 1.1.1.1
protected vrf: (none)
local ident (addr/mask/prot/port): (10.10.20.0/255.255.255.0/0/0)
remote ident (addr/mask/prot/port): (192.168.5.0/255.255.255.0/0/0)
current_peer 2.2.2.2 port 500
PERMIT, flags={}
#pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
#pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0
#pkts not decompressed: 0, #pkts decompress failed: 0
#send errors 0, #recv errors 0
local crypto endpt.: 2.2.2.2, remote crypto endpt.: 1.1.1.1
plaintext mtu 1438, path mtu 1500, ip mtu 1500, ip mtu idb GigabitEthernet0/0/1
current outbound spi: 0xC05AE021(3227181089)
PFS (Y/N): N, DH group: none
inbound esp sas:
spi: 0x7358E8DB(1935206619)
transform: esp-256-aes esp-sha256-hmac ,
in use settings ={Tunnel, }
conn id: 2008, flow_id: ESG:8, sibling_flags FFFFFFFF80000048, crypto map: Tunnel11-head-0
sa timing: remaining key lifetime (k/sec): (4608000/3551)
IV size: 16 bytes
replay detection support: Y
Status: ACTIVE(ACTIVE)
inbound ah sas:
inbound pcp sas:
outbound esp sas:
conn id: 2007, flow_id: ESG:7, sibling_flags FFFFFFFF80000048, crypto map: Tunnel11-head-0
IV size: 16 bytes
outbound ah sas:
outbound pcp sas:
local ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
remote ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
PERMIT, flags={origin_is_acl,}
local crypto endpt.: 1.1.1.1, remote crypto endpt.: 2.2.2.2
plaintext mtu 1500, path mtu 1500, ip mtu 1500, ip mtu idb GigabitEthernet0/0/1
current outbound spi: 0x0(0)
inbound esp sas:
inbound ah sas:
inbound pcp sas:
outbound esp sas:
outbound ah sas:
outbound pcp sas:
Here it is after a few min's of running.
sh crypto ipsec sa
interface: Tunnel11
PERMIT, flags={}
current outbound spi: 0xC79D41DF(3348971999)
PFS (Y/N): Y, DH group: group14
inbound esp sas:
sa timing: remaining key lifetime (k/sec): (4608000/3219)
IV size: 16 bytes
spi: 0xD0CE84DD(3503195357)
conn id: 2010, flow_id: ESG:10, sibling_flags FFFFFFFF80000048, crypto map: Tunnel11-head-0
sa timing: remaining key lifetime (k/sec): (4608000/3280)
IV size: 16 bytes
spi: 0x89570807(2304182279)
conn id: 2012, flow_id: ESG:12, sibling_flags FFFFFFFF80000048, crypto map: Tunnel11-head-0
sa timing: remaining key lifetime (k/sec): (4608000/3340)
IV size: 16 bytes
spi: 0x4EED1567(1324160359)
conn id: 2014, flow_id: ESG:14, sibling_flags FFFFFFFF80000048, crypto map: Tunnel11-head-0
sa timing: remaining key lifetime (k/sec): (4608000/3401)
IV size: 16 bytes
spi: 0x7D189F3B(2098765627)
conn id: 2016, flow_id: ESG:16, sibling_flags FFFFFFFF80000048, crypto map: Tunnel11-head-0
sa timing: remaining key lifetime (k/sec): (4608000/3461)
IV size: 16 bytes
spi: 0xA2C76783(2730977155)
conn id: 2018, flow_id: ESG:18, sibling_flags FFFFFFFF80000048, crypto map: Tunnel11-head-0
sa timing: remaining key lifetime (k/sec): (4608000/3522)
IV size: 16 bytes
spi: 0xBBB929E6(3149474278)
conn id: 2020, flow_id: ESG:20, sibling_flags FFFFFFFF80000048, crypto map: Tunnel11-head-0
sa timing: remaining key lifetime (k/sec): (4608000/3582)
IV size: 16 bytes
inbound ah sas:
inbound pcp sas:
outbound esp sas:
IV size: 16 bytes
spi: 0xC784E0ED(3347374317)
conn id: 2009, flow_id: ESG:9, sibling_flags FFFFFFFF80000048, crypto map: Tunnel11-head-0
IV size: 16 bytes
spi: 0xC916DD84(3373718916)
conn id: 2011, flow_id: ESG:11, sibling_flags FFFFFFFF80000048, crypto map: Tunnel11-head-0
IV size: 16 bytes
spi: 0xCD52A917(3444746519)
conn id: 2013, flow_id: ESG:13, sibling_flags FFFFFFFF80000048, crypto map: Tunnel11-head-0
IV size: 16 bytes
spi: 0xC4CB9992(3301677458)
conn id: 2015, flow_id: ESG:15, sibling_flags FFFFFFFF80000048, crypto map: Tunnel11-head-0
IV size: 16 bytes
spi: 0xCDD8ECF9(3453545721)
conn id: 2017, flow_id: ESG:17, sibling_flags FFFFFFFF80000048, crypto map: Tunnel11-head-0
IV size: 16 bytes
conn id: 2019, flow_id: ESG:19, sibling_flags FFFFFFFF80000048, crypto map: Tunnel11-head-0
IV size: 16 bytes
outbound ah sas:
outbound pcp sas:
inbound esp sas:
inbound ah sas:
inbound pcp sas:
outbound esp sas:
outbound ah sas:
outbound pcp sas:
Sorry it ikev2
Show crypto ikev2 sa
Show crypto sa
MHM
IPv4 Crypto IKEv2 SA
Tunnel-id Local Remote fvrf/ivrf Status
1 1.1.1.1/500 2.2.2.2/500 none/none READY
Encr: AES-GCM, keysize: 128, PRF: SHA256, Hash: None, DH Grp:2, Auth sign: PSK, Auth verify: PSK
Life/Active Time: 28800/12130 sec
IPv6 Crypto IKEv2 SA
Show crypto sa is not an option.
This good there is no issue
Then why does it create a new phase 2 connection every 60 seconds?
Ok' you use route based VPN which must show in crypto ipsec sa local and remote proxy 0.0.0.0
But I see subnet which point that one peer use policy based VPN that wrong.
Check remote peer config
Your is correct
MHM
where do you see that one is policy based and one is route based?
If I wanted to change this end to policy based, could you show me what that config would look like?
Step 1
Shut down tunnel
Step 2
Remove ipsec profile
Add
Crypto map <map name> ipsex-isakmp
set pfs group14
Match access <name of acl> <<-you need to add also acl from your local LAN to remote LAN
 Step 3
Apply crypto map under interface connect to remote peer
MHM
when trying the command Crypto map <map name> ipsec-isakmp it does not have ipsec-isakmp as an option. here are my options.
#Crypto map Cmap_Nash ?
<1-65535> Sequence to insert into crypto map entry
client Specify client configuration settings
gdoi Configure crypto map gdoi features
isakmp Specify isakmp configuration settings
isakmp-profile Specify isakmp profile to use
local-address Interface to use for local address for this crypto map
redundancy High availability options for this map
Crypto map <map name><seq> ipses-isakmp
Make seq number 10
MHM
