Multi VRF CE
pbenin
Hello.
How many VRF can be configure on Cisco1800 and Cisco2800 platforms?
Thank you very much.
Recommended positioning limits for throughput and the number of VRFs scale from 2 Mbps and 2 VRFs on the Cisco 870 Series, and up to 45 Mbps and 25 VRFs on the Cisco 3845 Integrated Services Router
http://www.cisco.com/en/US/products/ps6557/products_white_paper0900aecd8051fbdc.shtml
Narayan
aghaznavi
Level 5
Level 5
I think it depends on the protocols your running for example OSPF Support for Unlimited Software VRFs per Provider Edge (PE) Router.
Narayan
Thank you very much!
