Multi VRF
ronscott82
Is is possible to get the same network to advertise on 3 different OSPF processes in area 0 on 3 different vrfs.
ip vrf blue
description route-replication statements govern the RIB population in Areas 2-4
route-replicate from vrf services unicast ospf 11
route-replicate from vrf global unicast connected
route-replicate from vrf global unicast bgp 64548
ip vrf green
ip vrf red
ip vrf services
route-replicate from vrf red unicast ospf 2
route-replicate from vrf green unicast ospf 3
route-replicate from vrf blue unicast ospf 4
follow
As I get from your share config you have four VRF additional to global,
Shared service which is run OSPF 11 and VRF red,green,blue.
only one think I see you miss it, you need to config the redistribute under each OSPF because route-replication work only in this router other router don't know these route "replication" so you need to redistribute it.
