Multicast Across The Frame
mrashby
I am having a multicast issue. I can receive the stream on all of my Vlans internally, but the issue comes in when our satelite sites try to receive the stream across the Frame. Can anyone help me I think my issue is in the configuration on the satelite site router can someone help me with the config or point me in the direction of a standard config. Thanks.
8 Replies 8
when you say frame, does that mean Frame Relay ? If possible, can you post the configuration of your router ?
GP
Yes, I am talking about the frame-relay all of our sites are connected to the frame-relay. Also we have made the 6509 here at HQ the RP for the whole MCast network. I am posting the config with all the sections that have multicast lines in it....
no ip bootp server
ip multicast-routing
interface FastEthernet0/0
ip address 15.1.1.2 2.2.5.0
ip access-group 199 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim sparse-mode
speed 100
full-duplex
no cdp enable
interface Serial0/0
description Frame Relay
bandwidth 256
no ip address
ip pim sparse-mode
encapsulation frame-relay
logging event subif-link-status
logging event dlci-status-change
no fair-queue
frame-relay lmi-type ansi
interface Serial0/0.5 point-to-point
description EPVC TO AT&T
bandwidth 256
ip address 1.1.5.1 5.2.2.2
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim sparse-mode
no cdp enable
frame-relay interface-dlci 501 IETF
ip classless
no ip http server
ip pim rp-address 15.1.1.2
Also I am posting the MCast routing table....
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
L - Local, P - Pruned, R - RP-bit set, F - Register flag,
T - SPT-bit set, J - Join SPT, M - MSDP created entry,
X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
U - URD, I - Received Source Specific Host Report
Outgoing interface flags: H - Hardware switched
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 239.255.255.254), 2w2d/00:01:57, RP 1.1.1.2, flags: SJC
Incoming interface: Serial0/0.5, RPF nbr 0.0.0.0
Outgoing interface list:
FastEthernet0/0, Forward/Sparse, 2w2d/00:01:57
(*, 224.0.1.40), 7w0d/00:02:59, RP 1.1.1.2, flags: SJCL
FastEthernet0/0, Forward/Sparse, 7w0d/00:02:59
(*, 224.0.1.60), 7w0d/00:02:54, RP 1.1.1.2, flags: SJC
FastEthernet0/0, Forward/Sparse, 7w0d/00:02:54
Please let me know your thoughts on this. Just to recap all I can get the stream going to everybody here at HQ but at our sites in different locations I can't get the feed to any of those sites.
check with your provider if there are any intermediate devices unable (or unconfigured) to forward multicast traffic. If that is the case, you will need to build a tunnel over which to route the multicast traffic. Post the config of the remote site as well, and I´ll help you with the details.
Another question: is there IP reachability from your remote sites to the RP ? Can the remote sites ping the RP (address) ?
Nethelper
Ureka! My provider does not forward multicast traffic they said I have to build a GRE Tunnel. What is a gre tunnel? and what is it used for?
basically, a GRE tunnel is a way to get traffic through a network of devices with actually configuring those devices to support, in your case, multicast traffic. Since I do not know the exact configurations of your routers, here is a sample configuration:
Router1
interface Loopback0
ip address 1.1.1.1 255.255.255.0
interface Tunnel0
ip addresss 192.168.1.1 255.255.255.252
ip pim sparse-mode
tunnel source Loopback0
tunnel destination 172.16.1.2
ip mroute 0.0.0.0 0.0.0.0 Tunnel0
Router2
interface Loopback0
ip address 2.2.2.2 255.255.255.0
interface Tunnel0
ip addresss 192.168.1.2 255.255.255.252
ip pim sparse-mode
tunnel destination 172.16.1.1
In this example, network 172.16.1.0/30 is used for the IP addresses of the interfaces connecting your two routers. The tunnel IP addresses are arbitrary. If you have Loopback interfaces configured on your routers, you can use these addresses, otherwise it is recommended to create Loopback interfaces, the IP addresses are arbitrary as well.
Let me know if you run into trouble.
Nethelper
One more thing, I have 80+ sites and 1 RP am I to build 80 tunnels going to one switch (I am referring to the 6509 at HQ). Meaning are all my remote sites supposed to have 80 separate tunnels going to one switch or can one tunnel from the 6509 in HQ service all of the remote sites.
unfortunately, tunnels are point-to-point links, so you indeed would need to configure 80+ tunnel endpoints on the 6509, and one tunnel interface each on the remote sites. The 6509 should be able to handle this easily though.
Nethelper
Thanks for all the help.
