Multicast dropped. Why?
Hello!
I have very simple multicast network (scheme attached).
The problem is that router R1 (Catalyst 3750 both) is dropping multicast traffic on upstream interface.
Debug message is:
1d19h: IP(0): s=10.242.1.2 (Vlan2018) d=233.32.210.77 id=6006, ttl=28, prot=17, len=1358(1344), not RPF interface
1d19h: IP(0): s=10.242.1.2 (Vlan2018) d=233.32.210.77 id=6007, ttl=28, prot=17, len=1358(1344), not RPF interface
1d19h: IP(0): s=10.242.1.2 (Vlan2018) d=233.32.210.77 id=6008, ttl=28, prot=17, len=1358(1344), not RPF interface
1d19h: IP(0): s=10.242.1.2 (Vlan2018) d=233.32.210.77 id=6009, ttl=28, prot=17, len=1358(1344), not RPF interface
1d19h: IP(0): s=10.242.1.2 (Vlan2018) d=233.32.210.77 id=6010, ttl=28, prot=17, len=1358(1344), not RPF interface
1d19h: IP(0): s=10.242.1.2 (Vlan2018) d=233.32.210.77 id=6011, ttl=28, prot=17, len=1358(1344), not RPF interface
1d19h: IP(0): s=10.242.1.2 (Vlan2018) d=233.32.210.77 id=6012, ttl=28, prot=17, len=1358(1344), not RPF interface
1d19h: IP(0): s=10.242.1.2 (Vlan2018) d=233.32.210.77 id=6013, ttl=28, prot=17, len=1358(1344), not RPF interface
RPF check is Ok for the source 10.242.1.2:
R1#sh ip rpf 10.242.1.2
RPF information for ? (10.242.1.2)
RPF interface: Vlan2018
RPF neighbor: ? (10.242.128.49)
RPF route/mask: 10.242.1.2/32
RPF type: unicast (static)
RPF recursion count: 0
Doing distance-preferred lookups across tables
What does it mean? And how to fix it?
Here ar configs:
R1 config:
ip multicast-routing distributed
vlan 2018
name MCast_SOURCES
interface Loopback0
ip address 10.1.1.2 255.255.255.255
interface FastEthernet1/0/1
switchport access vlan 2018
switchport mode access
spanning-tree portfast
interface FastEthernet1/0/2
no switchport
ip address 192.168.12.73 255.255.255.252
ip pim sparse-mode
interface Vlan2018
ip address 10.242.128.50 255.255.255.240
ip pim passive
load-interval 30
router ospf 100
log-adjacency-changes
redistribute static subnets
passive-interface default
no passive-interface FastEthernet1/0/2
network 10.0.0.0 0.255.255.255 area 0
network 192.168.12.0 0.0.0.255 area 0
ip classless
ip route 10.242.1.2 255.255.255.255 10.242.128.49
ip pim rp-address 10.1.1.10 override
R2 config:
interface Loopback0
ip address 10.1.1.10 255.255.255.255
ip pim sparse-mode
no switchport
ip address 192.168.12.74 255.255.255.252
ip pim sparse-mode
switchport access vlan 14
load-interval 30
interface Vlan14
ip address 192.168.14.1 255.255.255.0
ip pim sparse-mode
ip igmp static-group 233.32.210.77
router ospf 100
no passive-interface FastEthernet1/0/1
For interdomain multicast routing MSDP must be configured at least.
Or source address of multicast group must be directly connected on the FHR.
7 Replies 7
mroute on R1:
R1#sh ip mroute
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
L - Local, P - Pruned, R - RP-bit set, F - Register flag,
T - SPT-bit set, J - Join SPT, M - MSDP created entry,
X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
U - URD, I - Received Source Specific Host Report,
Z - Multicast Tunnel, z - MDT-data group sender,
Y - Joined MDT-data group, y - Sending to MDT-data group
Outgoing interface flags: H - Hardware switched, A - Assert winner
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 233.32.210.251), 00:00:02/00:02:57, RP 10.1.1.10, flags: SP
Incoming interface: FastEthernet1/0/2, RPF nbr 192.168.12.74
Outgoing interface list: Null
(*, 224.0.1.40), 00:00:02/00:02:57, RP 10.1.1.10, flags: SJCL
Loopback0, Forward/Sparse, 00:00:03/00:02:56
Mroute on R2:
R2#sh ip mroute
(*, 233.32.210.251), 00:16:14/stopped, RP 10.1.1.10, flags: SJC
Incoming interface: Null, RPF nbr 0.0.0.0
Vlan14, Forward/Sparse, 00:16:14/00:01:54
(*, 224.0.1.40), 00:16:14/00:02:58, RP 10.1.1.10, flags: SJCL
FastEthernet1/0/1, Forward/Sparse, 00:15:33/00:03:16
Loopback0, Forward/Sparse, 00:16:14/00:02:58
But incoming traffic is dropped on R1/
Hello
Pim is missing on the SVI, try applying it.
interface Vlan2018
ip pim passive
ip pim sparse-mode <----
also show ip route and traceroute to 10.242.1.2 is this going the correct path as MC is expecting it to.
Kind Regards
Paul
Hi Paul
I've changed config, result is the same:
00:09:52: IP(0): s=10.242.1.2 (Vlan2018) d=233.32.210.77 id=55823, ttl=28, prot=17, len=1358(1344), not RPF interface
00:09:52: IP(0): s=10.242.1.2 (Vlan2018) d=233.32.210.77 id=55824, ttl=28, prot=17, len=1358(1344), not RPF interface
00:09:52: IP(0): s=10.242.1.2 (Vlan2018) d=233.32.210.77 id=55825, ttl=28, prot=17, len=1358(1344), not RPF interface
00:09:52: IP(0): s=10.242.1.2 (Vlan2018) d=233.32.210.77 id=55826, ttl=28, prot=17, len=1358(1344), not RPF interface
00:09:52: IP(0): s=10.242.1.2 (Vlan2018) d=233.32.210.77 id=55827, ttl=28, prot=17, len=1358(1344), not RPF interface
R1#sh ip pim int
Address          Interface                Ver/   Nbr    Query  DR     DR
                                          Mode   Count  Intvl  Prior
10.1.1.2         Loopback0                v2/S   0      30     1      10.1.1.2
192.168.12.73    FastEthernet1/0/2        v2/S   1      30     1      192.168.12.74
192.168.15.1     FastEthernet1/0/3        v2/S   0      30     1      0.0.0.0
10.242.128.50    Vlan2018                 v2/S   1      30     1      10.242.128.50
R1#sh ip mroute
(*, 233.32.210.77), 00:13:59/00:02:58, RP 10.1.1.10, flags: SP
(*, 224.0.1.40), 00:14:06/00:02:32, RP 10.1.1.10, flags: SJCL
Loopback0, Forward/Sparse, 00:14:04/00:02:32
R1#sh run int vlan 2018
Building configuration...
Current configuration : 106 bytes
interface Vlan2018
ip pim sparse-mode
load-interval 30
end
R1#sh ip route 10.242.1.2
Routing entry for 10.242.1.2/32
Known via "static", distance 1, metric 0
Redistributing via ospf 100
Advertised by ospf 100 subnets
Routing Descriptor Blocks:
* 10.242.128.49
Route metric is 0, traffic share count is 1
R1#sh ip route 10.242.128.49
Routing entry for 10.242.128.48/28
Known via "connected", distance 0, metric 0 (connected, via interface)
* directly connected, via Vlan2018
R1#trace 10.242.1.2
Tracing the route to 10.242.1.2
1 10.242.128.49 0 msec 8 msec 0 msec
2 * * *
3 * * *
4 * *
10.242.1.2 and 10.242.128.49 are in provider network and dont reply to ping.
Provider send me static multicast group 233.32.210.77.
I'm really confused what is wrong.
P.S. PIM passive mode means that the device will not send PIM messages on the interface nor will it accept PIM messages from other devices across this interface. The device will instead consider that it is the only PIM device on the network and thus act as the DR and also as the DF for all bidir-PIM group ranges. Isnt it?
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipmulti_pim/configuration/15-s/imc-pim-15-s-book/imc_stub_routing.html
on R2 try and enter the below static mroute:
ip mroute 10.242.1.2 255.255.255.255 192.168.12.73
Where is the multicast source 10.242.1.2 ? It is not part of Vlan 2018 (the 10.242.128.48/28) network...
HI Georg
I've tried it. It does not help.
R2#sh ip rpf 10.242.1.2
  RPF interface: FastEthernet1/0/1
  RPF neighbor: ? (192.168.12.73)
  RPF type: unicast (ospf 100)
R2#
R2#
R2#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
R2(config)#ip mroute 10.242.1.2 255.255.255.255 192.168.12.73
R2(config)#^Z
  RPF type: static
R2#
R2#sh ip mroute
(*, 239.255.255.250), 00:07:28/00:02:55, RP 10.1.1.10, flags: SJC
    Vlan14, Forward/Sparse, 00:03:33/00:02:55
(*, 233.32.210.77), 1d09h/00:02:51, RP 10.1.1.10, flags: SJC
    Vlan14, Forward/Sparse, 00:03:33/00:02:51
(*, 224.0.1.40), 1d09h/00:02:49, RP 10.1.1.10, flags: SJCL
    FastEthernet1/0/1, Forward/Sparse, 1d09h/00:02:47
    Loopback0, Forward/Sparse, 1d09h/00:01:56
The working option I've found is to assigne RP to R1 (Lo0: 10.1.1.2).
In this case multicast flows through my network.
But it is undesirable.
