multicast or broadcast a unicast packets over network
hi all
I have one application running on windows XP computer that send UPD packet to  ip address 10.10.10.2 . actually what i have to do is that i want to send/forward that packet distine for 10.10.10.2 to my other computers that are on other network following is scenario of my network
  PC1    sends UDP packet to 10.10.10.2 on Router1 port
PC1 ------------------------------------------------------------->[Router1]-------------------------------------------[Router2]--------------------[switch]--------------------(3xPCs connected)
        E0/0               E0/1                                E0/0        E0/1
following is configuration of my Routers
PC1 connected to Router1 has ip address 10.10.10.1
Router1>E/0/0 Ip address 10.10.10.2  subnetmask 255.255.255.0
Router1>E/0/1 Ip address 10.20.20.1  subnetmask 255.255.255.0
Router2>E/0/0 Ip address 10.20.20.2  subnetmask 255.255.255.0
Router2>E/0/1 Ip address 192.168.1.1  subnetmask 255.255.255.0
PCs connected to switch have following ip address
PC1  ip address 192.168.1.2 subnet mask 255.255.255.0 defaultgatway 192.168.1.1
PC1  ip address 192.168.1.3subnet mask 255.255.255.0 defaultgatway 192.168.1.1
PC1  ip address 192.168.1.4subnet mask 255.255.255.0 defaultgatway 192.168.1.1
my question  is that
is it possible to  send/forward unicast packet that is distine for 10.10.10.2 across other networks
is it possible to multicast/broadcast that unicast packet and send it across network
I m new i network field
kindly help me how can i multicast the unicast packet send me configuration accoding to my above topology
forbs
5 Replies 5
Marwan ALshawi
If you can send from pc1 to broadcast address 10.10.10.255
Enable multicasting on both routers
Covert broadcast to multicast on R1 and convert multicast to broadcast on R2 with LAN broadcast ip 192.168.1.255
See the below discussion that discuss simlar concept
https://supportforums.cisco.com/message/622198#622198
Hope this help
If helpful rate
if i send data on 10.10.10.255 (which is network broadcast address of 10.10.10.0) will it be possible that i can receive it on 192.168.1.0 network on other side of my network.?
fober
If you send the traffic to 10.10.10.255 then you should be able to configure ip helper-address and have it forward the traffic to the 192.168.1.0 network.
Rick
Rick
By converting the broadcast to multicast in router 1 and from multicast to broadcast in router 2 toward the LAN you can do it
Using the helper-map as diss used. In the link provided above. And the below article too
if helpful rate
