Multicast Routing across a 3rd party MPLS network
mike.rootvik
I need to provide multicast access accross our WAN which are connect over an MPLS network provided by a 3rd part provider.
I control the CE devices but the provider has controll of the PE.
Is there way to configure Multicast routing such that it van traverse the MPLS connections without being able to modify the PE's configurations?
Can you use mroute to traverse multiple hops, or does it require a direct connection to the end point?
olorunloba
Level 5
Level 5
You could ask your provider if they can give you a Multicast VPN service. If not, you coud configure a tunnel across the two sites and route the multicast traffic through the GRE tunnel.
