Info on NMD-36ESW
jeffland_98
Does anyone know were to find a data sheet on the NMD-36ESW? Specifically I'm wondering what the bandwidth is on the switching fabric. Also the only info I see on STP is it supports 802.1d - what about 802.1w, RSTP?
Thanks.
devang_etcom
Level 7
Level 7
Yes, I did see this but it doesn't give a bandwidth spec for the fabric. It comes close saying 200 Mbps per port (full duplex) which would be 7.2 Gbps minimum.
The pdf is (C) 2005 so I was hoping there was something newer which would indicate it can do 802.1w RSTP.
