Multicast routing over MPLS
VON CLAWSON
Level 3
Level 3
Topology is as follows.
Informacast server --> 3750-->2811-->MPLS-->2811-->3750-->iphone
I have configured ip pim sparse-dense-mode on all interfaces along this path.  One item that may be a problem is that the 3750's have the c3750e-universal-mz.122-50.SE image and it only gives me ip pim passive.  Since the multicast is going through this switch from the server I think they may be a problem.  but here are some output from the switches and routers.  Any help would be greatly appreciated.  By the way, the multicast to phones off of the first 3750 switch works.
3750
interface Vlan200
description Server
ip address 192.168.200.254 255.255.255.0
ip pim passive
ip igmp helper-address 172.16.12.9
end
interface Vlan253
description :Transit VLAN to WAN Router
ip address 172.16.253.1 255.255.255.0
ip pim passive
end
ip pim rp-address 172.16.12.1
GMI-LF-3750-Stack#sh ip igmp group
IGMP Connected Group Membership
Group Address    Interface                Uptime    Expires   Last Reporter   Group Accounted
239.255.255.254  Vlan200                  02:01:53  00:02:54  192.168.200.5
239.255.255.253  Vlan200                  02:01:52  00:02:59  192.168.200.9
239.255.255.250  Vlan200                  02:01:53  00:02:52  192.168.200.48
239.255.255.250  Vlan8                    03:02:30  00:02:59  192.168.80.7
239.255.255.250  Vlan19                   03:28:17  00:02:01  192.168.190.15
239.255.255.250  Vlan13                   03:31:44  00:02:59  192.168.130.2
239.255.255.250  Vlan3                    03:42:28  00:01:59  192.168.30.6
239.255.255.250  Vlan9                    2w1d      00:02:58  192.168.90.1
239.255.255.250  Vlan10                   7w1d      00:02:59  192.168.100.5
239.255.255.250  Vlan5                    8w4d      00:01:58  192.168.50.5
239.255.255.250  Vlan4                    43w4d     00:02:59  192.168.40.7
239.255.255.250  Vlan12                   44w5d     00:02:59  192.168.120.3
239.255.255.250  Vlan14                   44w5d     00:02:58  192.168.140.2
239.255.255.250  Vlan7                    44w5d     00:02:59  192.168.70.3
239.255.255.250  Vlan11                   44w5d     00:02:59  192.168.110.11
239.255.255.250  Vlan16                   44w5d     00:02:59  192.168.160.1
239.255.255.250  Vlan15                   44w5d     00:02:59  192.168.150.4
239.255.255.250  Vlan6                    44w5d     00:02:58  192.168.60.1
224.0.1.24       Vlan200                  02:01:51  00:02:54  192.168.200.17
224.0.1.60       Vlan5                    02:34:10  00:02:05  192.168.50.2
224.0.1.60       Vlan18                   3w4d      00:01:58  192.168.180.133
224.0.1.60       Vlan14                   44w4d     00:02:53  192.168.140.202
224.0.1.40       Vlan253                  01:57:24  00:02:10  172.16.253.9
GMI-LF-3750-Stack#sh ip mroute
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
       L - Local, P - Pruned, R - RP-bit set, F - Register flag,
       T - SPT-bit set, J - Join SPT, M - MSDP created entry,
       X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
       U - URD, I - Received Source Specific Host Report,
       Z - Multicast Tunnel, z - MDT-data group sender,
       Y - Joined MDT-data group, y - Sending to MDT-data group
       V - RD & Vector, v - Vector
Outgoing interface flags: H - Hardware switched, A - Assert winner
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 239.255.255.254), 10w4d/00:02:16, RP 172.16.12.1, flags: SJC
  Incoming interface: Null, RPF nbr 0.0.0.0
  Outgoing interface list:
    Vlan200, Forward/Sparse-Dense, 02:02:32/00:02:16
(*, 239.255.255.253), 12w5d/00:02:38, RP 172.16.12.1, flags: SJC
    Vlan200, Forward/Sparse-Dense, 02:02:32/00:02:21
(*, 239.255.255.250), 44w5d/stopped, RP 172.16.12.1, flags: SJC
    Vlan200, Forward/Sparse-Dense, 02:02:32/00:02:26
    Vlan8, Forward/Sparse-Dense, 03:03:10/00:02:21
    Vlan19, Forward/Sparse-Dense, 03:28:57/00:02:23
    Vlan13, Forward/Sparse-Dense, 03:32:23/00:02:20
    Vlan3, Forward/Sparse-Dense, 03:43:08/00:02:22
    Vlan9, Forward/Sparse-Dense, 2w1d/00:02:20
    Vlan10, Forward/Sparse-Dense, 7w1d/00:02:16
    Vlan5, Forward/Sparse-Dense, 8w4d/00:02:18
    Vlan4, Forward/Sparse-Dense, 43w4d/00:02:16
    Vlan12, Forward/Sparse-Dense, 44w5d/00:02:16
    Vlan14, Forward/Sparse-Dense, 44w5d/00:02:15
    Vlan7, Forward/Sparse-Dense, 44w5d/00:02:16
    Vlan11, Forward/Sparse-Dense, 44w5d/00:02:16
    Vlan16, Forward/Sparse-Dense, 44w5d/00:02:16
    Vlan15, Forward/Sparse-Dense, 44w5d/00:02:16
    Vlan6, Forward/Sparse-Dense, 44w5d/00:02:15
(192.168.200.44, 239.255.255.250), 00:03:06/00:02:27, flags: T
  Incoming interface: Vlan200, RPF nbr 0.0.0.0
    Vlan6, Forward/Sparse-Dense, 00:03:06/00:02:15
    Vlan15, Forward/Sparse-Dense, 00:03:06/00:02:16
    Vlan16, Forward/Sparse-Dense, 00:03:06/00:02:16
    Vlan11, Forward/Sparse-Dense, 00:03:06/00:02:16
    Vlan7, Forward/Sparse-Dense, 00:03:06/00:02:16
    Vlan14, Forward/Sparse-Dense, 00:03:06/00:02:15
    Vlan12, Forward/Sparse-Dense, 00:03:06/00:02:16
    Vlan4, Forward/Sparse-Dense, 00:03:06/00:02:16
    Vlan5, Forward/Sparse-Dense, 00:03:06/00:02:18
    Vlan10, Forward/Sparse-Dense, 00:03:07/00:02:15
    Vlan9, Forward/Sparse-Dense, 00:03:07/00:02:14
    Vlan3, Forward/Sparse-Dense, 00:03:07/00:02:17
    Vlan13, Forward/Sparse-Dense, 00:03:07/00:02:15
    Vlan19, Forward/Sparse-Dense, 00:03:07/00:02:17
    Vlan8, Forward/Sparse-Dense, 00:03:07/00:02:15
(*, 224.0.1.24), 10w4d/00:02:10, RP 172.16.12.1, flags: SJC
    Vlan200, Forward/Sparse-Dense, 02:02:36/00:02:10
(*, 224.0.1.60), 44w5d/00:02:23, RP 172.16.12.1, flags: SJC
    Vlan5, Forward/Sparse-Dense, 02:34:55/00:02:18
    Vlan18, Forward/Sparse-Dense, 3w4d/00:02:23
    Vlan14, Forward/Sparse-Dense, 44w4d/00:02:15
(*, 224.0.1.40), 00:36:53/00:02:41, RP 172.16.12.1, flags: SJPC
  Outgoing interface list: Null
(*, 224.0.1.41), 01:48:02/stopped, RP 172.16.12.1, flags: SP
(172.16.12.9, 224.0.1.41), 01:45:26/00:01:38, flags: PT
  Incoming interface: Vlan112, RPF nbr 0.0.0.0
(172.16.12.10, 224.0.1.41), 01:46:01/00:02:43, flags: PT
First 2811
GMILF-2811-VG2#sh ip igmp group
239.255.255.254  FastEthernet0/0.112      00:49:09  00:02:18  172.16.12.1
239.255.255.253  FastEthernet0/0.112      00:49:04  00:02:19  172.16.12.1
239.255.255.250  FastEthernet0/0.112      00:49:10  00:02:30  172.16.12.1
224.0.1.24       FastEthernet0/0.112      00:49:03  00:02:18  172.16.12.1
224.0.1.40       FastEthernet0/0.112      00:48:37  00:02:47  172.16.12.1
224.0.1.40       FastEthernet0/0.253      01:58:55  00:02:47  172.16.253.9
GMILF-2811-VG2#
GMILF-2811-VG2#sh ip mroute
(*, 239.255.255.254), 00:37:29/00:02:54, RP 172.16.12.1, flags: SP
  Incoming interface: FastEthernet0/0.112, RPF nbr 172.16.12.1
(*, 239.255.255.253), 00:37:24/00:02:53, RP 172.16.12.1, flags: SP
(*, 239.255.255.250), 00:37:28/00:02:51, RP 172.16.12.1, flags: SP
(*, 224.0.1.24), 00:37:21/00:02:58, RP 172.16.12.1, flags: SP
(*, 224.0.1.40), 00:38:11/00:02:21, RP 172.16.12.1, flags: SJPL
(*, 224.0.1.41), 00:37:50/stopped, RP 172.16.12.1, flags: SP
(172.16.12.9, 224.0.1.41), 00:37:32/00:02:31, flags: PT
  Incoming interface: FastEthernet0/0.112, RPF nbr 0.0.0.0
(172.16.12.10, 224.0.1.41), 00:37:50/00:02:58, flags: PT
Second 2811
ELECOR-2811-VG1#sh ip igmp group
224.0.1.40       FastEthernet0/0.112      01:06:05  00:02:30  172.19.12.1
ELECOR-2811-VG1#
ELECOR-2811-VG1#sh ip mroute
       Y - Joined MDT-data group, y - Sending to MDT-data group,
(*, 224.0.1.40), 00:38:36/00:02:12, RP 172.16.12.1, flags: SJCL
  Incoming interface: FastEthernet0/1, RPF nbr 10.255.255.5
    FastEthernet0/0.112, Forward/Sparse-Dense, 00:38:36/00:02:12
(*, 224.0.1.41), 00:38:11/stopped, RP 172.16.12.1, flags: SPF
(172.19.12.1, 224.0.1.41), 00:38:11/00:02:40, flags: PFT
  Incoming interface: FastEthernet0/0.112, RPF nbr 0.0.0.0, Registering
Please rate if this helps.
Giuseppe Larosa
Hello Vclawson,
some other information is needed, so some questions follows:
a) kind of MPLS service
with MPLS what do you mean?
If you have two sites connected by an MPLS L3 VPN you cannot setup multicast routing without cooperation with ISP unless you setup a point-to-point GRE tunnel between the two C2811
if you have a different type of service like a L2 VPN or simply you have bought a transport service you can go on in this way
b) you are trying to use PIM stub on the C3750 there is at least one interface that is not in passive mode and that connects the C3750 with the C2811.
c) another important point:
even if you are using PIM sparse-dense mode you need to configure a rendezvous-point, then groups served by RP will be treated as sparse and groups not served by RP are treated as dense.
But you still need  to configure a RP
see
http://www.cisco.com/en/US/docs/ios/ipmulti/configuration/guide/imc_basic_cfg_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1054581
Hope to help
Giuseppe
Thanks for the response.  The ISP has opened up the MPLS for multicast. The 3750 is configured with ip pim passive because the ios image only gives me that option. I can't configure sparse-dense-mode as I have on the other devices.  The question there is do I need to put a differen image on there so it is not a stub. I have configured an RP on both the 3750 and the 2811 but neither has worked. So the switchport that connects the 2811 needs to have ip pim passive?
Hello VcLawson,
but it is an MPLS L3 VPN or not?
if it is, the RP has to be chosen in agreement with the ISP
about C3750:
PIM stub routing moves routed traffic closer to the end user  and reduces network traffic. You can also reduce traffic by configuring a stub  router (switch) with the IGMP helper feature.
You can configure a stub router (switch) with the igmp helper  help-address interface configuration command to enable the switch to send  reports to the next-hop interface. Hosts that are not directly connected to a  downstream router can then join a multicast group sourced from an upstream  network. The IGMP packets from a host wanting to join a multicast stream are  forwarded upstream to the next-hop device when this feature is configured. When  the upstream central router receives the helper IGMP reports or leaves, it adds  or removes the interfaces from its outgoing interface list for that group.
see
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_installation_and_configuration_guides_list.html
the Layer3 interface to router should be configured or for pim (not for passive) if pim is not supported I would not configure igmp helper towards the C2811 but only on client Vlans.
the IGMP helper-address should work for clients that are on Vlans defined on the C3750.
For sure the interface on the C2811 towards the C3750 needs to have pim enabled in order to process relayed IGMP joins and reports (if any)
Hope to help
Giuseppe
