Multicast
Just Kennie
Level 5
Level 5
1. On a mcast router that is failing RPF test, from source 10.0.0.0/24, is it safe to define an mcast default route like this
ip mroute 0.0.0.0 0.0.0.0 172.16.0.1 instead of the subnet route
ip mroute 10.0.0.0 255.0.0.0.0 172.16.0.1
2.How do I know when a router formely using RPT,had started using the SPT. Below is the output
R3(config)#do sh ip mro 230.0.0.1
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
       L - Local, P - Pruned, R - RP-bit set, F - Register flag,
       T - SPT-bit set, J - Join SPT, M - MSDP created entry,
       X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
       U - URD, I - Received Source Specific Host Report,
       Z - Multicast Tunnel, z - MDT-data group sender,
       Y - Joined MDT-data group, y - Sending to MDT-data group
Outgoing interface flags: H - Hardware switched, A - Assert winner
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 230.0.0.1), 00:30:10/stopped, RP 2.2.2.2, flags: SJCL
  Incoming interface: FastEthernet0/0, RPF nbr 10.1.23.2, Mroute
  Outgoing interface list:
    Loopback0, Forward/Sparse, 00:21:07/00:02:27
(10.1.10.10, 230.0.0.1), 00:00:13/00:02:50, flags: LJT
    Loopback0, Forward/Sparse, 00:00:13/00:02:46
Lei Tian
You should not use a default static route unless you know all multicast traffic passing this router is only one direction; The direction of source tree and share tree might different; a default static route could cause problem. If you have to use static route, use more specific.
When the last hub router (the one connect to receiver) receive multicast exceed the threshold, it will start switchover process. On the lost hub router, the "J" flag on (*,G) entry indicate the switchover process.
HTH,
Lei Tian
