Multicasting on WAN;
AKK
Hi All,
I need your help to enable multicasting over the WAN. I have a 6500 SW connected to router and from router I have 3 MPLS links connected given by different service provider running with EBGP. I have around 30 branches running EBGP with Service Provider, and want to multicast VC to branch location from DC.
How to do that, what are all the things I need to enable in my 6500 Switch as server is connected to this switch.
Thanks in advance.
AKs
Mahesh Gohil
Level 7
Level 7
For me it is working fine with below set of commands
At HO side
global
ip multicast-routing
LAN:
ip igmp version 3
WAN:
ip pim sparse-dense mode
ip igmp static-group source
At Access side
global
LAN:
ip igmp version 3
WAN:
ip igmp join-group
You should verify pim neighborship by "sh ip pim neighbor" and to view traffic "sh ip mroute"command
Mahesh
